high beam
Old Oct 30, 2008 | 07:46 AM
soozookabluS2k's Avatar
Default high beam
hey guys, would 70 watt bulbs be fine for my high beams? bascially they r the pure yellow nokya bulbs that i want for the drl's i wouldnt use them really other than that. Since the drl runs at a lower wattage would it be fine even though stock is rated at 55w?
Old Oct 30, 2008 | 09:48 AM
dparm's Avatar
You risk damaging the wiring harness, the connectors, and the headlamp assembly.
It's a very bad idea.
Old Oct 31, 2008 | 08:18 AM
s4play's Avatar
There's another solution but do NOT use those filament bulbs since they get too hot.
Kinda off topic but when we turn on our high beams, do the low beams turn off? Never tried........?
rk
Old Oct 31, 2008 | 08:54 AM
dparm's Avatar
The low beams stay on. It's bad for HIDs to turn off and on again quickly.
Fog lamps typically turn off.
Old Oct 31, 2008 | 09:14 AM
s4play's Avatar
I believe our high beam bulb is a H7?
I was not thinking of HID but rather a special high output LED bulb....
I've been using one in my s2000 headlight for the 7443 blinker bulbs:
(middle bulb)
Old Nov 1, 2008 | 02:47 AM
06S2k07Si's Avatar
Our high beam bulbs are an H1. I just replaced mine with the Osram Nightbreaker H1.
See here: http://www.osram.com/osram_com/Consumer/Au...AKER/index.html
For more info on lighting this website has some good info:
http://www.danielsternlighting.com/home.html
Brian
Old Nov 1, 2008 | 09:38 PM
Picturepro's Avatar
I've been using PIAA 55ww...>110w
work great for over a year, and I dont get the white light tunnel vision
I like the 2500k temp
I had the silverstars and took them out for the PIAA
http://www.eautoworks.com/product-PIAA-14385.htm
Old Nov 2, 2008 | 11:32 AM
takeshi's Avatar
I'll 2nd the PIAA's.
Old Nov 4, 2008 | 02:00 PM
asukadc's Avatar
maybe i 'll have to try it out
Saki GT
Mar 22, 2024 12:56 PM
aznsupastar
Oct 31, 2018 06:52 AM
Kengthao91
Jul 21, 2013 05:03 PM
Kiwi-S2000
Jun 18, 2008 12:51 PM
redleader
Aug 19, 2001 05:43 AM
