How do I connect my amp wire to the battery?
Old Jun 21, 2002 | 11:42 AM
S4 Mike's Avatar
Default How do I connect my amp wire to the battery?
I have a 4 guage wire that I need to connect to the + terminal. I'm trying to decide between replacing the battery clamp w/ an aftermarket one which has two hookups (one for stock and one for the amp wire) vs adding some sort of ring terminal somewhere to the stock setup. Does anyone have a good idea how to connect the amp wiring to the battery? Pictures would be greatly appreciated. Thanks,
Mike
Old Jun 21, 2002 | 01:44 PM
matrix's Avatar
Either of those will work. I recommend also placing a fuse near the connection to protect from a short.
Old Jun 21, 2002 | 01:45 PM
Tifosi Red's Avatar
I used a gold 4 gauge ring crimp terminal and just added it onto the existing bolt down connectors on the battery terminal. Make sure you put an in-line fuse holder close to the battery though I have the fuse holder fixed to the left hand inner fender with some double sided adhesive fasteners and sheaved the cable in flexible conduit to protect it and keep a stock look.
Its way late here or else I would snap a pic for you
Tif
Edit: sorry Matrix, our posts crossed.
Old Jun 21, 2002 | 02:06 PM
matrix's Avatar
No problem...looks like we had the same thought on it anyway.
Old Jun 21, 2002 | 08:08 PM
lucid's Avatar
RF makes a very good clamp on inline fuse. The fuse is right on the battery clamp(what I use) and allows you to easily connect the 4 gauge wire to it with its torx nut lock.
Old Jun 22, 2002 | 04:09 PM
StormBringer's Avatar
THe 4 gauge crimp connecters work fine. I have that then the big monster fuse about 8 inches on the line attached near the vin. Then run all the way back to a distruubution box and it works fine to feed two medium sized amps. I will need to use the nice gold plated battery cap when I go to the ppi stuff as I need to run 2 4 gauges to the back and then the crimp connectors start to have trouble delivering the load.
Old Jun 23, 2002 | 12:19 AM
RollingAudio's Avatar
Hey Lucid, Whats the part number for the Rockford Fosgate clamp on fuse holder? I checked their website and other places but can't seem to find the right one. Thanks
Hawkeye2jz
Aug 29, 2015 04:29 PM
s2krey
May 9, 2008 02:10 PM
billyjoho
Nov 30, 2006 08:23 AM
cshamash
Mar 5, 2006 12:46 PM
cshamash
Mar 4, 2006 08:22 AM
