Is A Line Driver Needed?
Old Jul 9, 2003 | 02:41 PM
InsaneInNC's Avatar
I was talking with a guy at Phoenix Gold this afternoon, originally to discuss a question I had about their amp (see my posts on this thread), when we started to discuss various other options, including the Phoenix Gold Line Driver (TLD22).
I am very skeptical that this would really add anything to what I think will be a good setup (Alpine CDA-9813 HU, Phoenix Gold Tantrum 600.4 amp, MB Quart RCE-216 Reference Component Speakers, and eD e8A.44 Subwoofer in HLAURANT enclosure).
I understand the concept of what a line driver does, but with good patch cables between the HU and amp, wouldn't the 4 volts output of the HU be sufficient? Would doubling the output to 8 volts really be that advantageous? I would definitely say yes if the HU output was only 2 or less volts.
At this point in time, I'm leaning against adding this unit. However, I would like to hear some of your thoughts on this matter. Is anyone using a line driver, in their setup? Please no . Thanks!
Old Jul 9, 2003 | 05:05 PM
mgiang7's Avatar
Mike,
there's been debate on the boards that the sub-woofer output on the new Alpine head-units are weak (i.e. not 4 volt) i haven't been following it too closely but there's enough evidence to make me wonder. my suggestion would be to go without one and add it later if the subwoofer sounds weak. i really don't think you'll have that problem...
Old Jul 9, 2003 | 05:09 PM
PJK3's Avatar
4 volts should be more than adequate for your needs... 8 volts seems a bit much to me... i doubt the noise rejection will be necessary and your amp will produce full output even if you use a 4 volt preamp signal.
Old Jul 9, 2003 | 05:12 PM
PJK3's Avatar
[QUOTE]Originally posted by mgiang7
[B]Mike,
Old Jul 9, 2003 | 05:33 PM
InsaneInNC's Avatar
[QUOTE]Originally posted by PJK3
[B]sigh...
Old Jul 9, 2003 | 07:41 PM
PJK3's Avatar
actually -- the whole alpine -15 db vs +15 setting is sort of an inside joke for us...
thread on related issue... needless to say, it's a rather boring and tedious read w/ lots of me being pissy cause i was tired... . since that thread, i've spoken w/ some tech heads, and i was instructed that at +15 (0db reduction) the pre amp outs produces a 4v signal and that as you dial down closer to +0 (-15 db reduction) the pre-amp signal drops off dramatically (even to the point where the input gains of some amps cannot properly compensate).
Old Jul 10, 2003 | 04:42 AM
Darksyde's Avatar
A line driver improves the head room on your system. The only time I would suggest using one is a competition level system, but for the average listener it's justed an added bell and whistle.
SlidinS2k
Nov 28, 2006 02:59 PM
Darien1629
Oct 21, 2005 03:29 AM
8BALL
Jun 2, 2004 09:30 AM
J Nick
Jan 9, 2004 09:58 AM
KeithD
Feb 12, 2002 02:34 PM
