Modifry Install problem
Old Feb 22, 2009 | 09:30 AM
Swags04's Avatar
Default Modifry Install problem
I installed it per instructions, after I turn my car on, nothing is changed... all 4 wires are hooked into main harness, alpine head unit with 3.5mm plug inserted... The switches on the actual
Does my head unit need to change in any menu's?
Not ONE option works.
Also, what is the 2nd blue plug that came out of the oem head unit, I originally thought THAT was the DCI controller plug, but realized the wire colors were on the actual plug that the new headunit connects to
[/img]http://farm4.static.flickr.com/3309/3301109804_086c3eed57.jpg?v=0[img/]
Any help would be appreciated.
Old Feb 22, 2009 | 09:32 AM
Nandska's Avatar
Image tags were messed up.
Old Feb 22, 2009 | 11:04 AM
s2k aok's Avatar
i'd email modifry an/or post this in the electronics section.
Old Feb 22, 2009 | 09:29 PM
starchland's Avatar
double check all your connections and triple check to make sure all your wires are correctly hooked up and that you have power and no burnt fuses. Also, check with a multimeter. Its funny I did the same install but had to solder all my connections and it worked fine.
Wish I could be of more assitance, but its relatively simple to figure out unless youve got a bum unit.
Old Feb 22, 2009 | 09:41 PM
ryanmatic's Avatar
You've probably already double-checked this, but make sure that the Modifry 3.5mm plug is plugged into the wired remote port and not a 3.5mm audio in port (many HUs seem to have both).
Old Feb 23, 2009 | 07:11 AM
JDR159's Avatar
Obvious, but have to ask: Did you set the dip switches for an Alpine?
Old Feb 23, 2009 | 07:57 AM
candymanjl's Avatar
make sure those crimp things are actually making a connection at all. those are kinda hit or miss in my experience, that's why I don't use them anymore, soldering has yet to fail me
Old Feb 23, 2009 | 08:17 AM
camuman's Avatar
i ad a similiar problem when i did mine. turns out that grey/white and white/grey are different rofl. you need to triple and quadruple check the wires. 99% you wired wrong, 1% DOA. check each wire carefully and make sure the colors are correct. also, did you change the dipswitch settings? make sure they are set right also per instructions depending on which brand HU you have.
G/L.
Old Feb 26, 2009 | 01:11 PM
mr5parkle's Avatar
anyone hear from modifry lately? i ordered and emailed but no response from him since monday.
Old Mar 5, 2009 | 12:06 AM
TheSilentSK's Avatar
I ordered from Modifry! The PnP harness for my Alpine unit is awesome. I had a problem with the DCI so i e-mailed Mr. Guru. He got back to me the next day.
CasperSPT
Feb 17, 2013 10:25 AM
plutonium239
Sep 30, 2007 09:37 AM
2000silvers2k
May 7, 2006 07:56 AM
zuppy51
Dec 2, 2004 12:49 PM
supman
Aug 1, 2004 01:15 AM
