Need help....AGAIN...
Old May 9, 2004 | 08:22 PM
NFRs2000NYC's Avatar
Default Need help....AGAIN...
Ok guys...Im sending in my Audiobahn to get replaced due to a faulty LPF, so in the meantime, I got my friend's Rubicon 302.
Now...its a 2 channel amp....
there are 4 speaker inputs, however, one of the speaker wire screw/holding thingies is missing...So I have NO choice but to bridge the amp.
I am Running an Alpine Type R DVC (2ohm+2ohm) sub.
The amp is rated at:
4ohm stereo : 75w x 2
8ohm bridged: 150 x 1
2ohm stereo: 150 x 2
4ohm bridged: 300 x 1
1ohm stereo 150 x 2
2ohm bridged 300 x 1
So I assume I have to use the 4th option...4ohm bridged...correct??
If so, please tell me how to wire this up.
Is it....
+ of right channel and - of the left channel.... (thats what the amp says is bridged)
so the positive goes to one coil +
negative goes to the OTHER coil -
But now what? Do i connect the other two remaining terminals on the sub together???
Thanks boys!
Old May 9, 2004 | 08:33 PM
Ok...I think I have figured it out, jest let me know if Im right.
For a 2ohm load....
+ to coil a....then + from coil a to + on coil b.
- to coil b....then - from coil b to - on coil a.
Correct?
Jeez im dumb.
Old May 10, 2004 | 07:40 AM
Am I correct junkies?
Old May 10, 2004 | 08:00 AM
PJK3's Avatar
umm...
you can't actually get a 2 ohm load out of a 2 ohm DVC.
what you've described is a 1 ohm load. (parallel)
you'll have to run this sub at a 4 ohm load (series) and get 300 Wrms x 1.
it would have to be:
amp r+ > a +
a - > b +
b - > amp l-
here's a pic that should help: http://www.jlaudio.com/tutorials/wiring/in...ndex.html#1dvcs
remember -
when wiring in series, you add resistances. Rtotal = R1 + R2 + R3 + R....
when wiring in parallel, you've got to do the fractions:
1/Rtotal = 1/R1 + 1/R2 + 1/R3 +...
so, in this case in parallel: 1/Rtotal = 1/2 + 1/2 = 2/2. the inverse of 2/2 = 2/2 = 1 ohm.
but you're not stable @ 1 ohm.
so, in series: Rtotal = 2 + 2 = 4 ohm. which is stable.
now -- if you had a 4 ohm DVC... parallel would be a good option:
1/Rtotal = 1/4 + 1/4 = 1/2 since, this is 1/Rtotal, we need the inverse inverse of 1/2 to get Rtotal. the inverse of 1/2 is 2, so Rtotal = a 2 ohm load.
lithoman
Jul 11, 2011 06:48 AM
ASpec818
Jul 21, 2009 09:09 PM
hoangcs
Feb 28, 2007 07:42 PM
Tom0
Mar 6, 2006 07:01 PM
NFRs2000NYC
Jun 30, 2003 11:03 AM
