Need help with beeping noise
Old Jan 19, 2023 | 10:40 AM
33daniel3's Avatar
Default Need help with beeping noise
Just got an S2000 for a steal, all because of this unknown beeping that drove the previous owner insane. Its the 4 beeps that it makes whenever the key is in the ignition, but it doesn’t stop. The key is out, the beeping continues to a point where it eventually drains and kills the battery. Ive unplugged the green cable underneath the steering column with the 2 wires, it keeps beeping. Anyone know how to completely disable this? It only locks from the outside so I cant even accidentally lock my keys inside, therefore rendering the key in ignition chime useless. Even when it had a very poorly wired in antitheft system in place before, all spliced in with only electrical tape (that has since been removed and all wires have been patched) , it still beeped. Any help is appreciated.
Old Jan 20, 2023 | 08:04 AM
spider2k's Avatar
Active Streak: 30 Days
check to see if the door pin triggers are messed up. sounds like the car thinks a door is open.
Old Jan 20, 2023 | 09:50 AM
dwb993's Avatar
This is the most likely culprit, and an easy fix.
Slightly off-topic: The 4 beeps the car makes when the key is in the ignition and the door is open are Morse Code for the letter "H". You can thank me later.
freq
Oct 8, 2016 03:17 AM
rmphoto
Feb 23, 2015 06:21 AM
estooki
Feb 17, 2012 08:54 PM
JEEBS
Aug 31, 2010 12:28 PM
AlexC
Aug 11, 2004 10:37 AM
