Need help with car wireing
Old Jul 23, 2007 | 07:41 PM
York00s2k's Avatar
Thumbs up Need help with car wireing
Ok im new here and i searched for simalar topics to no avail. I need some advice on how to finish the system I have for my S. My goal is to have a 3 or 2 way component system, single sub, duel amps, running from a new deck. I Currently have my 2 amps ( JL 300/4 ( mono to the sub) and a JL E2150 for the components). I also have a JL 10W3v2 in a custom drop in box in the trunk. I am debating on a 2 or 3 way component system. I am gong with JL but anyone have any advice on this? what sounds better in our cars? also i have NO idea on how to run the wire to do this setup. what do i need to use 2 amps. I have never had a real system in a car and i want this one right. Please help
Old Jul 25, 2007 | 08:42 AM
other_vortechs2k's Avatar
I can't really comment on how this will sound because I'm still running stock in my S. But, the best way to power multiple amps is to run a 4AWG wire to a distribution block in the trunk, and then 8 or 4AWG wires to each amp, depending on the power you're talking about, which doesn't sound like too much. Hopefully you have a deck with front/rear/sub preamp outputs, if not you can just split the signals using "Y" RCA cables, but you'll lose a little signal quality.
Old Jul 28, 2007 | 07:10 PM
York00s2k's Avatar
Sweet thanks. Only other question is if i put my tweeters in the pillers, how do i run the wireing to them from the crossover. does it do throught the boot in the door? I just dont want to screw it up
Old Jul 28, 2007 | 11:23 PM
revhi's Avatar
Yes you have to fish the wire though the door. Depending on the power of your amps, a distro block may not be enough. I have 2 separate 4 gauge run to each amp. Also if your radio only has one output, the amp should have a n in and out. You could jump the second amp from the first one, but same as above mentioned, you loose sub control and fade on the deck.
hondavet
Apr 9, 2013 04:55 PM
ll1l2l1l2lll
Jan 2, 2013 04:32 PM
oilerfan17
Feb 13, 2008 03:47 PM
AndyS2
Jan 23, 2004 12:36 PM
Speedracer
Jan 30, 2003 08:21 AM
