Need help with new Alpine HU install for 99 TL
For all the skeptics out there here is how you integrate the bose amp into aftermarket on the 99 tl
There is a seperate 12 pin black plug attached the the back of the stock radio (black in color)... Look carefully you will see it looks like 2 wires and the speaker pair sets..
Connect these wires as shown... White/Yellow to your accessory (pin 1)... Black to your ground (Pin 3)... white to right rear output on aftermarket deck (pin 12).... black to left rear output of deck (pin 9)....
Do it at your own risk... This is for a 99 TL but obviously some stock stereos are different.. I am not responsible for anything that you may cause.. Please test wires..
Originally Posted by Stealth_SUX_,Aug 6 2008, 03:29 PM
Actually ur all taking the hard way out.. You can integrate the subwoofer.. we always give the option to our customers to integrate or rewire.
You just have to find the subwoofers amp turn on wire, and find if the signal going to the sub is low level or high level...
You can integrate any boss, jbl, monsoon, or any factory system if you have patients and actually test wires.
Done it many times.. not on a tl yet but its all the same when it boils down to it, just differ wire colors.
JD NC
Jan 31, 2013 06:12 AM
StknCaS2k
Jul 8, 2003 12:40 PM
