Need to tap wire that "senses the ignition switch"
Old Jan 8, 2010 | 03:50 PM
dammitjim's Avatar
Default Need to tap wire that "senses the ignition switch"
I need to find a wire to tap that "senses the ignition switch" according to doc for the heated seats I'm installing. Can someone recommend a good place to tap into for this?
There is a separate lead that goes direct to battery/battery source, so I imagine this ignition switch lead just prevents the seats from turning on if the ignition isn't turned on.
Old Jan 8, 2010 | 05:22 PM
oth's Avatar
oth
assuming you need +12v when the ignition is on, there is an appropriate
connector in the under-dash fuse box:
(from the technical FAQ)
one more thing - I'd recommend adding a fuse to that wire if there isn't one
already, as the fuse leading to that terminal is 40 amps, and you can do a lot of
damage with a short before a 40 amp fuse will blow...
Old Jan 8, 2010 | 06:38 PM
dammitjim's Avatar
Thanks. I knew about those but for some reason I didn't think one of them was ignition
Fujin
Feb 20, 2019 07:55 AM
JawKnee
Feb 6, 2012 09:02 AM
liquidgsr
Dec 6, 2011 05:16 AM
PaulWil
Feb 1, 2008 11:31 AM
9kI4
Aug 26, 2007 12:46 PM
