No power to Sony headunit
Old Aug 9, 2005 | 07:26 AM
PJK3's Avatar
check the accessory fuse. 99% sure that's your problem.
in fact, don't just check it. replace it.
Old Aug 9, 2005 | 07:48 AM
jwa4378's Avatar
For an aftermarket HU, you should have tapped into a switched power source (usually ignition). Check that tap and make sure it is still intact. If it was installed by a shop (Best Buy did this on one of my older decks), check for an in-line fuse on this line.
And as Phil pointed out on another thread....fuses do not have to LOOK bad to be bad.
John
Old Aug 9, 2005 | 10:01 AM
aggie's Avatar
Thanks all for the advice, I'll be trying those out tonight.
Old Aug 9, 2005 | 07:20 PM
aggie's Avatar
It was the Accessory fuse - it looked OK at a glance but a careful inspection showed the break. I was starting to go crazy driving around Houston without any music.
Thanks PJK3 and all others!
Old Aug 11, 2005 | 12:10 PM
PJK3's Avatar
Somm2k
Jun 25, 2014 01:29 PM
aphex4000
Aug 14, 2010 03:48 PM
vtec4life
Jul 31, 2008 07:36 PM
captainbk
Dec 3, 2006 07:00 AM
LiQUiD iCE
Apr 12, 2005 06:20 AM
