Ok i've had it!
Old Mar 25, 2006 | 08:27 PM
Avernus's Avatar
Default Ok i've had it!
2 ohms 4 ohms 8 ohms! I've done as much as i can to learn about it but i've come up short. Please explain this in detail if you dont mind.
Old Mar 25, 2006 | 08:50 PM
xviper's Avatar
Please explain independence...
Are you sure you want to talk about "independence"? This refers to the state of being independent.
I'm no expert on this sort of thing, but I thought you should at least have the correct term so your question will be more accurate. I think you want to know about "impedence". This, for speakers and amps, is measured in ohms (or resistence).
This might help you far more than I can:
http://science.howstuffworks.com/question501.htm
Old Mar 25, 2006 | 08:53 PM
Avernus's Avatar
Thank you very much. typo . I'm checking out the link now.
Old Mar 25, 2006 | 09:18 PM
WLAURENT's Avatar
Here are some pics - may help understand speaker wiring (parallel, series, SVC, DVC).
Old Mar 26, 2006 | 06:51 AM
Avernus's Avatar
Why do you need ohms and what do they actually do. I know there resistance but why would you want more on a sub. It seems like resistance would make it harder to move the sub.
Old Mar 26, 2006 | 07:33 AM
jwa4378's Avatar
You will want more resistance if your amp calls for it. Some amps are not stable at lower impediances, and require 4-ohms to operate. Also, the lower the ohm, the hotter the amp will get (as its working harder). Some people like to run their amps cool for efficiency reasons.
John
evolution
Jul 3, 2013 07:02 PM
nr7
May 6, 2009 11:16 AM
AndrewStwoK
Oct 20, 2008 02:35 AM
littlerocket777
Mar 6, 2006 04:47 PM
2004S2000
Apr 2, 2004 09:26 PM
