Passesger Speaker Buzzzzzzzzzzzzzz
I recently noticed that my passenger side speaker buzzes every time I turn on the radio/CD Player. This started happening right after the dealership replaced my dead battery (after winter storage - forgot to unplug battery
What I noticed is this only happens when the car is on and not when the car is off. I also noticed that the buzzing still happens even if i disconnect the sub wire from the battery.
I tried taking out the deck and checked the rear wire harness and it looked fine (from what it seemed
) after reading a tip to check the rt speaker wire from behind the deck.
I know its had to diagnose the problem but do you guys have any ideas? Should I take it to a shop to check out?
Setup:
Stock Deck
Stock Speakers
JL 300-1 AMP
JL Stealthbox
For what its worth, a friend's friend's friend's shop installed the sub for free. Can anyone help? Thanks
)What I noticed is this only happens when the car is on and not when the car is off. I also noticed that the buzzing still happens even if i disconnect the sub wire from the battery.
) after reading a tip to check the rt speaker wire from behind the deck. I know its had to diagnose the problem but do you guys have any ideas? Should I take it to a shop to check out?
Setup:
Stock Deck
Stock Speakers
JL 300-1 AMP
JL Stealthbox
Its hard to say with a factory unit powering your spks. Re-check the ground on the firewall side, and check the RCA cables to be sure its not touching each other or "grounding out". Unplug the SUB RCA at the AMP and see it it does it again. If not, theres your prob.
Originally Posted by RS2000,May 29 2008, 06:17 PM
Switch in your driver side speaker to see if it works. Check cables and wires for shorts. Probably a short somewhere.
If it's buzzing only when the car is on, you have a ground loop. Recheck all your grounds - use a multimeter to ohm between the ground points and amplifier. Should have < 4ohms. Anything over that, you have a problem.
Fusiondynamics
Feb 3, 2005 09:51 PM
