Phoenix Gold Tantrum 500.2
Old Jan 29, 2007 | 05:28 PM
dangators05's Avatar
Default Phoenix Gold Tantrum 500.2
Can a PG Tantrum 500.2 be run safely at 2 ohms?
Old Jan 29, 2007 | 08:10 PM
smurf2k's Avatar
says so here
http://www.cardomain.com/item/PHOT5002
Old Jan 30, 2007 | 05:32 AM
darkknight1999's Avatar
Yes in mono setup.
Old Jan 30, 2007 | 07:07 AM
"2 Ohms Bridged / 1 Ohm Stereo Stable"
Could someone explain to me the difference between bridged and stereo?
Basically, I want to run 2 subs. Is it as simple as straight wiring 2 subs at 4 ohms each to achieve 2 ohms bridged?
Old Jan 30, 2007 | 12:53 PM
smurf2k's Avatar
in stereo, 1 channel (left or right) will have its discrete signal and so will the other one
with bridging, signal (voltage) is taken from 2 channels/sources .. the 2ndary source has its (inverted) signal flipped
the two signals (voltage) are combined constructively, to get double the strength.. which means more powah.. but you lose the discrete L/R signals so its not stereo
you can wire 2 4-ohm subwoofers in parallel to present a 2ohm load to the amplifier. 1/R = (1/4 + 1/4). and you would do this bridging your subwoofer outputs
Old Jan 30, 2007 | 06:31 PM
This is exactly the answer I needed. Thanks for the info.
Old Jan 31, 2007 | 04:34 PM
jwa4378's Avatar
Dan, did you lose my email?
If you need some help, let me know. I am working for the FL AG now.
John
13darkknight
Apr 16, 2009 10:38 PM
mugenrsx
Nov 2, 2008 09:07 AM
evan2
Sep 24, 2008 09:48 AM
J Nick
Nov 5, 2004 06:21 AM
Go_Nads
Jul 21, 2004 05:01 PM
