Por favor senor... need help in oil-water sensor
Old 05-24-2008, 12:20 PM
lotus7racer's Avatar
Default Por favor senor... need help in oil-water sensor
Another favor....
Trying to connect an oil sensor and water temp sensor to an aftermarket digital dash,
Do you know what is the ECU pin # of the oil sensor and the water temp sensor?
The output wire from the ecu to the gauge.
Is there an output wire from the s2000 ecu for these sensorS?
Thanks again...
Old 05-25-2008, 02:35 AM
NFRs2000NYC's Avatar
I don't believe the S2000 ECU provides that info...you will need sensors to get it. I am 95% sure.
Old 05-25-2008, 04:57 AM
So, I have to direct wire the oil & temp sensor to the gauge huh?
I thought there is wire in the S2000 ecu I can tap to go to the dash.
ZachS45
02-13-2018 08:35 AM
crisskro
10-09-2013 07:46 AM
seansniper
10-28-2012 08:04 AM
lotus7racer
05-28-2008 07:40 AM
ack5252
02-19-2008 12:50 PM
Quick Reply: Por favor senor... need help in oil-water sensor
