power turn on - mulitamp
Old Oct 14, 2004 | 03:31 PM
J Nick's Avatar
Default power turn on - mulitamp
I have an alpine 9815 which has a turn on lead out but for a multi-amp install can it be split to the two amps - if not - from where do I get a power turn on lead to the two amps.
Thanks for assist in this
nich.
Old Oct 14, 2004 | 03:50 PM
spider2k's Avatar
Active Streak: 30 Days
you shouldbe fine using the one output for turning on both amps. its a 500mA output but ive ran 3 at a time with no issues.
if you are concerned you can use a relay . run the blue turn-on to terminal 85, ground 86, constant battery (fused at about 3 or 5 amps) for 87 and run terminal 30 to the 2 amp turn on inputs.
Old Oct 14, 2004 | 06:51 PM
NFRs2000NYC's Avatar
Just split the wire in two bro, youll be fine.
Old Oct 14, 2004 | 07:45 PM
PilotKD's Avatar
Or if you're mounting the two amps side by side, you could just connect the head unit's turn on lead to one amp and then use a jumper wire from that one to the 2nd amp. I've done this myself and it works fine.
Old Oct 14, 2004 | 07:54 PM
werd
Brennon
Oct 3, 2006 09:01 PM
formulaofsuccess
Sep 13, 2005 05:24 PM
deanjones
Aug 11, 2005 03:55 PM
GeorgeP
Jul 17, 2002 03:55 PM
virtualtom
Jun 6, 2001 12:15 AM
