Q's about fuses
Old Sep 27, 2007 | 09:46 AM
Kenpo_S2000's Avatar
Default Q's about fuses
I recently took out my cd/dvd player out of the S2K. It had a wire harness set up so that was cake. I plug back in the old player. It works fine for about a week. Then all of sudden driving around it turns off. The red light still blinks but nothing else happens.
To make things more weird it turns on yesterday for about 5 seconds and then shuts off again.
I have a MY01. I wanted to know what fuses I need to replace to see if that is the problem. I don't want to put back in the dvd player but I will if the factory isn't going to work.
Thanks for the help.
Old Oct 4, 2007 | 03:58 AM
MacGyver's Avatar
If it came on again, even for a short time, it's not a fuse. Make sure your radio doesn't the same problems as the TSB for the older radios (typically it shuts off under high volume after a few minutes). There were a number of bum radios out there...
Old Oct 4, 2007 | 08:02 AM
It did end up being the ACC fuse I don't remember the exact same one but there are two ACC fuses. This was a 10 amp mini red fuse. I didn't get any replies and spent some time on the search forum. It turns out someone else had the exact same problem.
I pulled the fuses and it was definetely that. I bought a new fuse put it in and the radio came to life.
Old Oct 4, 2007 | 08:34 AM
MacGyver's Avatar
Are you sure the radio came back on, then (the actual audio portion)? The blinking red light is on a different fuse than the main power for the radio, but I cannot fathom a way the radio could actually produce sound if the fuse was blown... there's just no way for power to make it to the audio section.
Old Oct 4, 2007 | 01:35 PM
Could the fuse have the same effect as a light bulb that burns out. Its hard to explain but with the light whatever makes the connections are still working a bit but once they get totally burned away its out for good.
Maybe the connection with the fuse was not totally seperated.
I don't know but the sound did come on for about five seconds. I remember because I thought it was a fluke and I was all excited. Once it went out again I had a bad feeling thinking it was the radio. When I pulled the fuse I could see the middle was totally gone. I put in the new fuse and it has been great since then.
Old Oct 4, 2007 | 05:34 PM
MacGyver's Avatar
It's possible that a small portion of the melted fuse fell back into the middle, but it's unlikely... still, the possibility is there.
Old Oct 5, 2007 | 10:10 AM
modifry's Avatar
Honorary Member
I guess now we wait for the fuse to blow again?
slowpokeS2K
Aug 6, 2010 12:40 PM
Kenpo_S2000
Sep 28, 2007 06:40 AM
nicku
Apr 16, 2007 07:21 AM
downshift9G
Apr 10, 2007 05:55 AM
CA_Brit
Apr 13, 2005 04:51 PM
