question abt audio system
Old Jan 20, 2009 | 12:55 PM
nr7's Avatar
nr7
Default question abt audio system
Hi guys
i have boston acoustics rc61 from my old car. still in good condition most part. but 1 tweeter and 1 passive crossover doesn't work anymore due to the water damage. my question is can i use old speakers with different passive crossovers and tweeters.
i'm thinking replacing passive crossover and tweeter. or buy 2 passive crossovers and 2 tweeters , then use with the old speakers. is it possible? and what kind of tweeters should i buy to compatible with our s2000. or any better set up suggestions will be appreciated. thanks.
Old Jan 20, 2009 | 02:43 PM
DFWs2k's Avatar
I would just buy a new set of speakers, so that you have something designed to work together...
Old Jan 21, 2009 | 12:15 PM
nr7's Avatar
nr7
anyone? ...i still wanna use my boston mid speaker...feel bad to throw away...any suggestions?
Old Jan 21, 2009 | 01:45 PM
DFWs2k's Avatar
it should "work" but it won't be optimal.
Old Jan 22, 2009 | 04:36 AM
Neutered Sputniks's Avatar
I wouldn't say it's not going to be optimal.
Many manufacturers use similar xover frequencies so switching between manufacturers isn't terrible, and may, in fact, create a better sound for you.
Could always switch to an active x-over system and then it makes absolutely no difference whether your tweeters match the woofers you're putting in - you set your own xover frequencies.
Realistically, bottom line, you're not going to hurt your woofers or tweeters using xovers from a diff manufacturer and if you're picky you can very well improve the sound. Remember, what one manufacturer says is good or 'perfect' setup doesn't mean that applies to everyone - everyone's ears are different.
Old Feb 5, 2009 | 04:49 PM
nr7's Avatar
nr7
thanks ppl....i'll buy Xover any try to install it...
AndrewStwoK
Oct 20, 2008 02:35 AM
Rusted_nailz
Feb 17, 2008 06:15 AM
Monster1pt8TQ
Aug 14, 2006 10:42 AM
Lainey
Nov 6, 2004 02:27 PM
jvrabel
May 12, 2003 02:07 PM
