Radar Detector
Old Jul 23, 2006 | 11:32 AM
Troyz0r's Avatar
Default Radar Detector
Just a general questions if someone can answer.
If you mount your Radar Detecor ontop of secrete compartment(inbetween head rests, infront of windscreen), does it effect your radars range? sorry for newb. question. Didnt know if the curve of windshield or anything like that effects it.
Old Jul 23, 2006 | 02:37 PM
importkid's Avatar
it might have an effect on police hitting you from the side or behind you with the top up but as far as straight on (95% of the time) i dont see why it would.
Old Jul 18, 2019 | 08:30 AM
oth's Avatar
oth
Theoretically the ideal position for detecting radar is high and unblocked, so the windblocker, lower and
partially obstructed by the windshield frame, is probably slightly worse. The question is, does it really matter?
A radar detector will detect radar long before the radar can measure your speed. I had a friend many years
ago who would leave his detector on the floor of his 911, about the worst possible spot, and had no problem
detecting radar in time, but this was before wide use of instant-on radar - now you need to detect it when
it's sampling vehicles far ahead of you.
A likely bigger impact would be on its laser-detecting abilities. It's a much narrower beam, usually aimed at
your license plate, and you'd likely pick up much less scatter further back. But again, does it matter? for the
most part, when you detect laser you're already being measured, and the alarm simply informs you that
you're going to get a ticket...
Old Jul 19, 2019 | 06:55 AM
Chuck S's Avatar
I can't see the warning lights, signal strength, or sensor count unless mounted on the dash. Purely academic now that I reside in Virginia.
-- Chuck
Old Jul 19, 2019 | 12:06 PM
kwakhead's Avatar
I've ran a Valentine 1 mounted on the modifry GoPro mount for years & never had any issue. I use the Bluetooth adapter & use my phone as a remote display using a modifry dash mount
stockae92
Apr 4, 2012 07:27 AM
J_STATUS
Aug 4, 2008 04:23 PM
kenta
Jul 18, 2008 05:55 AM
Wisconsin S2k
May 4, 2005 08:04 AM
acx
Jul 11, 2002 08:55 AM
