Rear speaker wiring
Old May 21, 2005 | 03:51 PM
PapiChulo's Avatar
Default Rear speaker wiring
my question is this and i cant seem to locate it, i was going to go ahead with the lucid idea and put rear speakers into those panels but im confused on teh wiring, are there speaker wires in the area already ? do i need to run wires ? how do i do this ?
Ive done some searches and cant find a clear answer so any help would be great thank you in advance ( Ive already pm'ed a couple of you since "Car mod time" is in about 12 hrs.)
Old May 21, 2005 | 05:33 PM
dierk's Avatar
Lucid used to sell a connector for this. It let you tap the rear channel signals coming from the stock head unit.
To answer your specific questions:
No, there are no speaker wires in the area already
Yes, you need to run your own wires
I'm not sure exactly how to do this but several people on this forum should know.
Old May 22, 2005 | 04:36 AM
jimmij's Avatar
In the 2000 there are no rear speaker wires. You will need to tap into the wiring harness on the back of your radio. The left rear + is position 6 and - is 16. Right rear is + 5 and - is 15. This will allow you to use the fade controls on your radio. Hope this helps.
Old May 22, 2005 | 10:27 AM
Picturepro's Avatar
On the 04-05 the clairion radio has output for 6 disk changer
is that wired to the trunk location?
I disconected it from the head unit to use the Ipod adapter
The parts guy found a couple wiring harnesses that make it a plug and play
for the 6disk changer the the center consol
Wire are there ...... for speakers.... out of the Headunit... they must go somewhere...
do they just go out 6" and end off the radio?
Old May 23, 2005 | 04:04 AM
jimmij's Avatar
On the 04-05 you will see a wiring harness on the drivers side of the radio. I had to take out the radio to get to it.
Old May 23, 2005 | 07:28 AM
PdC's Avatar
PdC
The 04-05s come with optional oem headrest speakers, so likely the wiring is already there. They plug in under the seats, I am guessing the cars come wired up to that plug.
Old May 23, 2005 | 08:17 AM
SheDrivesIt's Avatar
To the best of my knowledge, the 04-05s do not have any wiring to the rear either. Their are wires in the radio harness plug (unlike earlier model years that only had open spaces in the plug). The wire leads are just taped back to the harness though.
Old May 23, 2005 | 08:36 AM
jimmij's Avatar
The plug is to the left of the radio. You need to either take out the radio or the side panel on the drivers side. I just did this 2 weeks ago. There is no wiring to the back of the car.
Old May 23, 2005 | 02:05 PM
PdC's Avatar
PdC
Hmm, my bad then, sorry!
Old May 24, 2005 | 08:57 AM
Joe04sk's Avatar
In the 04's there is a rear speaker harness behind the driver's side rear panel close to the center console.
gforgary
Feb 27, 2014 08:34 AM
garyz
Jul 1, 2012 05:20 PM
paivag
Feb 28, 2007 06:56 AM
golfpro
Jul 7, 2006 05:00 AM
joecro
Sep 9, 2001 10:49 AM
