Removing the battery
I'm going to remove the battery to install my amp this weekend.
Was wondering if there are any issues with the alarm when doing this?
Or will it fine when I reconnect the Batt??
Thanks
Alan
Thanks
Alan
You may want to check the owner's manual for your alarm. My guess is that you will need to turn it off before you take out the battery, especially if your alarm came with a backup battery. Might get noisey otherwise.
Also, I assume you have replaced your HU to something other then stock. Otherwise, make sure you know where your HU code is.
