Request: DIY: Boot amp & sub installs
Old Oct 8, 2012 | 11:16 PM
S2000&1's Avatar
Default Request: DIY: Boot amp & sub installs
Hey guys, i apologise profusely if this has been covered 1000 times, but maybe im slightly retarded. I cant find any DIY sound installs particularly for the wiring paths from the head unit to the boot in terms of wiring up and amp and a sub (and obviously connecting the door speakers to the amp as well), If anyone knows of one such post please can you guide me to it, or just some decent advise could go down well.
Thanks in advance.
Old Oct 9, 2012 | 01:15 AM
kryptonite's Avatar
Member
Spotter
Presumably you know how to wire an amp correctly.
This post isn't for your amp specifically but it goes over how to remove the panels you need to etc.
Also I found it easier to slightly remove the carpet rather than run the wiring along the side as it was a little too tight a fit.
https://www.s2ki.com/s2000/topic/440...l__edfc+in+ap2
Also my amp sits in my spare tire well.
Bought mine here
https://www.s2ki.com/s2000/topic/232978-amp-rack/
Old Oct 9, 2012 | 06:04 PM
darkknight1999's Avatar
Here you go: How to wire your S2000
Old Oct 9, 2012 | 10:38 PM
S2000&1's Avatar
Thanks guys, this is really helpful. Guess its gonna be a busy weekend ;-)
Muchas gracias
Old Oct 11, 2012 | 06:53 AM
oth's Avatar
oth
In addition to John's guide, here are a few more useful threads:
Running power cable to trunk
grommet by battery
more on wires to trunk
running wires through the center console
running speaker wires into doors
Old Oct 11, 2012 | 04:36 PM
kryptonite's Avatar
Member
Spotter
grommet by battery
As for running the power wire, I would run it on the drivers side as there are a lot of power lines in that area. Running your RCA's on that side would cause some disruption imo.
Old Oct 11, 2012 | 10:37 PM
S2000&1's Avatar
im sporting a right hand drive though, so i have the eurospec s2000. So i think i could probably do passengerside and avoid the powerlines. but i'll take a look and let you know. I'll get stuck into it tomorrow morning. Thanks again for the advice
V6 Donut
Feb 27, 2017 08:09 AM
azynboi03
Sep 16, 2008 02:54 PM
crav3s2k
Jun 10, 2008 07:50 PM
hoangcs
Feb 28, 2007 07:42 PM
