Seeking system advice
Old Aug 2, 2004 | 04:06 PM
AcnSux's Avatar
Default Seeking system advice
I currently have a pair of 6.5 Kappa Perfects, and the Infinity REF7540A amp. I am wondering if it is possible to run two 8 inch Subs with the Wlaurent enclosures. I would like to run the perfect off the front two channels and run the two subs off the rear two channels, will this be possible?
Old Aug 3, 2004 | 08:25 AM
ruexp67's Avatar
In theory it should work.
You did not specify what subs you are looking at. When your bridge the rear channel, you get ~ 300 watts rms at 4 ohms. So as long as you don't need subs that will blow out the fenders, you should be ok.
Old Aug 3, 2004 | 09:16 AM
AcnSux's Avatar
I am still trying to research which sub I should get...so I'm open to suggestions. Is it worth hooking up two subs? Will it be noticably louder if I have 300 rms going to it. I talked to a local stereo shop and he said that I should get a two ohm sub and just hook up each sub to one channel, instead of bridging it.
Old Aug 6, 2004 | 11:25 AM
AcnSux's Avatar
can anyone else provide any input?
Old Aug 6, 2004 | 01:39 PM
johnnydev's Avatar
Not sure why your being ignored...I have a similar set up except I have a single 8" sub in a wlaurent enclosure. It's a JL 8xxx (i forget). Anyways, it's the one with 2 voice coils. I bridge 2 channels of a 4 ch amp to it and I push it pretty hard. It cranks much better than I ever expected but I could not, or at least I would not run two of those subs without a dedicated amp. In fact if I ever upgrade my system, that would be what I'd do, add another 8" in a wlaurent enclosure and drive them off a seperate amp. There are several frequent posters that could give you specific things to consider about 1 vs 2 and what you should get in either case.
Hopefully they'll chime it.
jd
h i 9 h r 3 v z
Dec 27, 2012 09:34 PM
Fusiondynamics
Aug 19, 2004 10:32 AM
natedoggs2k
Aug 12, 2004 11:56 AM
Brutewes
Mar 5, 2004 11:22 AM
AndyS2
Jan 23, 2004 12:36 PM
