Soft top switch problem
Old Jan 13, 2007 | 08:02 AM
S1997's Avatar
Default Soft top switch problem
Both of my windows raise and lower normally using the door switches. But when I raise or lower the top, the right window lowers all the way down as normal; but the left window lowers only half way. Suggestions about how to fix it, anyone? I tried replacing the ROOF switch on the console, but that wasn't the problem.
Old Jan 13, 2007 | 09:41 AM
Pulse's Avatar
My '02 did the same thing, not to much later the actual window switch started having the same problem (auto-down wouldn't take it all the way down, then the switch itself acted up).
Followed reset instructions and this would fix it for a while. Evetually I had to have it repaired.
Old Jan 13, 2007 | 09:43 AM
PJK3's Avatar
it doesn't sound exactly like it.... but have you tried the auto-rolldown fix?
it could the sign that the pulser is going bad. i'm pretty sure there's a TSB out there for the pulser problem (if that is what your problem is...) does the auto-down at the door switch work properly?
Old Jan 13, 2007 | 10:26 AM
S1997's Avatar
You guys are great! The reset procedure did work! I've had the S for seven years now, and this is the first time I've had window troubles. Thanks again!
Old Jan 14, 2007 | 06:56 PM
PJK3's Avatar
no problem.
just be aware, that this is seldom a long term fix. most likely you'll continue to have this problem and it will be intermittent in nature. sometimes, i used to go 2 days or 2 months between having to do the reset.
there is a TSB for this problem, and even w/ a 2000 you may be able to get a goodwill consideration repair.
https://www.s2ki.com/forums/index.php?showtopic=275210
(iirc, the part is pretty dang expensive otherwise... like $300+ i think? )
Zen1
Jun 10, 2016 06:25 AM
nwaaa11
Nov 24, 2010 02:27 AM
MAV2
Sep 17, 2002 09:24 AM
Squeezer
Mar 21, 2001 06:03 PM
