Sound Setup
I'm thinking of replacing the stock speakers with aftermarket as they have better sound quality. I will be getting a sub to go in the truck space with new door speakers(and possibly headrest units later on). I searched around and found the below. Please tell me if they will fit and work properly and if they will work with the audio controls on the dash.
Sub : Alpine SWR-1043D
•10" subwoofer with dual 4-ohm voice coils
•Kevlar reinforced pulp cone with Santoprene rubber surround
•cast aluminum frame with perimeter venting and radial finned heat sink
•frequency response: 26-200 Hz
•power handling: 300-600 watts RMS (300 watts per coil)
•peak power: 1,800 watts
•sensitivity: 83 dB
•top-mount depth: 5-7/8"
•sealed box volume: 0.5-1.0 cu. ft.
•ported box volume: 0.8-1.5 cu. ft.
Door Speakers:
2x Alpine SPS-610C 6.5in Woofer 2x Alpine SPS-610C Tweeter
Frequency Response: 70 Hz - 22 kHz
Impedance Rating: 4
Impedance: 4 Ohms
Mid Range Size: 6.5 Inches
Mid Range Style: Polymer
Mounting Depth: 6 cm
Power Handling: 240 W Peak, 80 W RMS
Recommended Power Range: 80 W RMS
Sensitivity: 88dB
Speaker Size: 6.5 Inches
Super Tweeter Style: Silk Dome
Tweeter Size: 1 Inch
Woofer Material: Polymer
Woofer Surround Material: Rubber
Dimensions:
Width: 12.5 cm
Height: 8.0 cm
Depth: 5.6 cm
AMP: Alpine MRP-M500
•mono subwoofer car amplifier
•300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
•variable low-pass filter (50-200 Hz, 24 dB/octave)
•variable bass boost (0-12 dB at 50 Hz)
•subsonic filter (15 Hz, 24 dB/octave)
•Class D amp with MOSFET power supply
•CEA-2006 compliant
•STAR Topology (minimizes internal noise and prevents ground interference)
•speaker- and preamp-level inputs
•gold-plated screw terminals
•fuse rating: 30A x 2
•8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
•10-11/16"W x 2-7/16"H x 9-9/16"D
Deck: Pioneer DEH-P8400BH
General features:
•CD receiver with AM/FM tuner
•built-in MOSFET amplifier (14 watts RMS CEA-2006/50 peak x 4 channels)
•MIXTRAX for a DJ-inspired audio/visual experience
•built-in HD Radio tuner with iTunes tagging
•built-in Bluetooth for hands-free calling and audio streaming
•plays CDs, CD-Rs, and CD-RWs, including discs loaded with MP3 and WMA files
•detachable face with dot matrix LCD display, plus customizable display and key colors
•remote control
Audio features:
•Advanced Sound Retriever (ASR) for improved sound quality from compressed music files
•5-band equalizer with six preset tone settings
•3-level loudness
•high- and low-pass filters
•subwoofer level control
Expandability:
•built in iPod control — no adapter necessary, but adding Pioneer's optional connecting cable lets you leave your iPod cable at home
•App Mode offers limited control of music apps through iPhone connection
•compatible with satellite radio tuner
•inputs: front panel auxiliary and rear-panel USB inputs
•outputs: 6-channel preamp outputs (4-volt front, rear/subwoofer)
Other info:
•compatible with most factory steering wheel audio controls (adapter required)
•CEA-2006 compliant amplifier
Will the above work well together? I have no experience with car audio. What else will i need to have this working? Like to use the dash controls.
To power all this would I need another battery?
I would really appreciate any input on this.
•sensitivity: 83 dB
Door Speakers:
Impedance Rating: 4
Impedance: 4 Ohms
Sensitivity: 88dB
Dimensions:
Width: 12.5 cm
Height: 8.0 cm
Depth: 5.6 cm
•CEA-2006 compliant
General features:
•remote control
Audio features:
•3-level loudness
Expandability:
Other info:
I'd get better door speakers - that's where most of your sound reproduction comes from
http://www.amazon.com/Alpine-SPR-17S...ine+type+r+6.5
I'd also amplify the door speakers - maybe get a 4 channel amp to drive door speakers and sub as well.
For that you'd need a less power hungry sub http://www.crutchfield.com/p_500SWS1...D4.html?tp=111
