Speaker Static
Old Oct 31, 2003 | 04:51 AM
BlueIrishS2k's Avatar
Default Speaker Static
Ok. I've got Polk speakers that came with my Lucid rear panel system in my car. In the last few days I've heard some rattling coming from either them or the area around them (I haven't had an opportunity to test yet to find out which). I can't imagine that I did but do you think I blew them?
Old Oct 31, 2003 | 05:06 AM
ruexp67's Avatar
Not enough information.
Are you running an amp? If so how much power does it push? If not, stock HU or Aftermarket?
Who did the wiring, and how?
It could be something rattling in the trunk, top well or under your seat or even in the center console area.
It could be a blown speaker
It could be a loose connection
It could be the speaker coming loose from it's mounting.
It could be another component like the amp or HU.
Is this with the CD, Radio or both?
Old Oct 31, 2003 | 06:27 AM
[QUOTE]Originally posted by ruexp67
Old Oct 31, 2003 | 08:04 AM
ruexp67's Avatar
Could it be the MP3 file itself. or did it work before? Does it play on other players?
Can you check for a loose connection?
Old Oct 31, 2003 | 12:02 PM
PJK3's Avatar
if it's only certain songs, it could be a resonance issue...
check the rubber surrounds on the speakers to make sure they have good integrity.
also, put one of the CD's in w/ the offending song set on repeat. pull your seats forward and try to find the noise... press on various panels and such to see if you can stop it.
Old Nov 1, 2003 | 11:04 PM
CRX7's Avatar
Remember that those plastic panels are not great mounts. You don't want the power up too high on those rear speakers, just enough to create some fill.
Old Nov 2, 2003 | 09:14 AM
That's a good thought, too. Maybe I'll tear them out and see what I can do to firm up the mounting.
Old Nov 7, 2003 | 05:06 AM
I've pulled the speakers and it's definitely them though I'll be damned if I can figure out what happened. I can't tell if the cone has detached or if it was supposed to be how it is and the static-like noise is coming from somewhere else. I played around with it a little bit and was able to get the noise to stop by applying pressure in a couple of places but nothing that will work permanently.
Time to buy new ones, I guess. I'm thinking this will be the last set of Polk speakers I ever buy!
jdm_rsx
Apr 22, 2010 03:51 AM
cshamash
Apr 1, 2006 11:02 AM
silver/black
Apr 1, 2005 07:04 AM
Saint_Spinner
Jul 17, 2003 08:55 AM
ErikKlenke
Jul 16, 2001 12:01 PM
