Passenger speaker stopper working
Old Mar 31, 2005 | 04:50 AM
silver/black's Avatar
Default Passenger speaker stopper working
Just stopper working yesterday on way home from work. XM and left speaker sound normal but no passenger side speaker at all. My 01 has no tweeter just 2 door speakers.
I have the stock head unit with a 200 watt amp.
Has the amp burned out 1 channel or did the wires to the speaker come loose ? Maybe something else ?
Old Mar 31, 2005 | 06:18 AM
PJK3's Avatar
stock speakers? if so, go buy new speakers, chances are you blew it.
otherwise, i (or anyone else here) is going to need a lot more info about your setup to address your issue. models, parts, how installed, connections, etc.
one thing you can do is flip-flop the outputs on your amp and see if the problem changes side. that will cut the system in half and let you know whether your problem is amp to HU or amp to speaker.
Old Mar 31, 2005 | 08:06 AM
Got aftermarket speakers.
I will swap the amp output and see if that helps to diagnose the problem.
Thanks
Old Mar 31, 2005 | 01:03 PM
NFRs2000NYC's Avatar
This happened to me, and all it was , was the RCA for the channel fell off due to vibrations. Just plugged it back in.
Old Apr 1, 2005 | 05:22 AM
PJK3's Avatar
yeah, flip speaker outs and amp inputs.... (you'll be checking the connections in the process)
that should isolate it a good bit in either case.
still not enough info to really do much more.
Old Apr 1, 2005 | 07:04 AM
I swapped the outputs on the amp and the right side started playing and then the left went out then I flipped a switch on the back of the amp and now everything works fine ?
Thanks
wonderd
Mar 9, 2009 09:34 AM
s2kjunkie
Jan 22, 2009 07:45 AM
cshamash
Apr 1, 2006 11:02 AM
Saint_Spinner
Jul 17, 2003 08:55 AM
ErikKlenke
Jul 16, 2001 12:01 PM
