Speed Sensitive Volume
Old Jun 23, 2001 | 07:51 AM
REVN S2K's Avatar
I connected the sound sensing volume control of my Blaupunkt CD50 to the White/Black wire, between the Brown and the Lt Grn. It is between the two wires you mentioned in your earlier post but it is not Black/White. There are actually two white/black wires, don't use the one between the black/yellow and the Lt Grn/Red.
This connection now works. Using the highest adaptive setting it seemed to work fine with the top down up to 60mph, I didn't have enough room to try it any faster, yet.
Old Jun 25, 2001 | 01:30 AM
modifry's Avatar
Honorary Member
Originally posted by REVN S2K
Some of the info that you supplied seems to be inconsistent with my cars wiring harness]
Sorry 'bout the confusion, I should have said "white/black" instead of "black/white". But I see you found the correct wire anyway.
Is that a typo on your drawing, showing pin 12 to be a light green instead of the white/black? Or is that how your car is wired?
Old Jun 25, 2001 | 02:52 AM
REVN S2K's Avatar
Sorry for the typo I have since updated the htm document.
Dean
Old Jun 30, 2001 | 10:55 PM
phyphorous2ki's Avatar
JVC digifine unit have it built in. I don't know how it works, but all you have to do is just install the unit like a regular unit. It's an older unit though, I think the newer ones are better, but I'm Not sure. Good thing about that unit is you don't have to buy seperated parts to make it work.
vstypicals
Sep 26, 2013 10:08 AM
lotus7racer
Mar 9, 2009 05:34 AM
OGPackin
May 5, 2006 07:13 AM
BlackS2000Turbo
Aug 19, 2002 05:00 AM
JDMS2K
Dec 26, 2000 03:59 PM
