Stereo Install Help
Old Oct 10, 2003 | 11:45 AM
RxRx7's Avatar
Default Stereo Install Help
Had my stereo taken out of my RX7 b/c I sold it, so I figured I should put it in the S2000 b/c why have it just laying around? Only problem is, I've never put in a stereo before and I have been reading up and bought some stuff off lucid's site. but I can't picture every single step in my head so I need some help especially in the amp/sub dept. like where do I tap the remote wire for the amp, has anyone one down custom fiberglass molding (thinking of a 10" where the tools go so you don't lose that much trunk space)., how to run wires through the doors to the door speakers, is it poss to put 2 amps under the seat, what to do if my 6 1/2 dont' fit in the factory housing,. I'm thinking of doing it peice by peice b/c I'm figuring it's going ot take a while b/ it's my first time, but I want to run most of wires all at once. Thanks!
Old Oct 10, 2003 | 11:22 PM
NFRs2000NYC's Avatar
Ill help you out....if you want something like this or to that extent.....
1. Remove battery, look on the firewall about 5 inches down.....see the grommet, shove the power through there, and down the pass. side door sill.
2. Speakers......if they dont fit, try to get spacers, however, the door panel might not go back on properly if they are too deep. Speaker wire is run through the door grommers......open the door all the way, and look at the rubber pieces between the "car" and door.....hardest step out of the whole install.
3. remote wire....on the harness of the HU it should have a remote wire....tap that.....
I will clarify whatever you need to know....so let me know......
Best of luck!
s2knkde
Aug 27, 2010 04:24 PM
nMeOnE
Oct 11, 2004 04:30 PM
RxRx7
Oct 19, 2003 09:00 PM
Waterbug
Jul 28, 2003 01:01 PM
