is there a constant 12vs in the trunk area ?
Old Nov 19, 2004 | 02:45 AM
Bass's Avatar
Default is there a constant 12vs in the trunk area ?
looking for a constant 12v that i can tap to help a buddy with his Siruis
don't want to have to run a new line from the fuse box if i don't have to
Thanks
Old Nov 19, 2004 | 04:37 AM
MacGyver's Avatar
Trunk light?
Old Nov 19, 2004 | 05:26 AM
Bass's Avatar
Thanks Dan!!!! - That will work!!
Hi to Merri
Old Nov 20, 2004 | 12:11 AM
NFRs2000NYC's Avatar
I think the trunk light is only on when the trunk is open. I think the circuit breaks the power when the trunk is closed.
Old Nov 20, 2004 | 04:45 AM
MacGyver's Avatar
Doesn't matter... the fact that a light exists at all means 12V is somewhere back there, and ground is easy to find.
Old Nov 20, 2004 | 08:06 AM
doh!
Old Nov 22, 2004 | 02:17 PM
AusS2000's Avatar
Check out Modifry's mod page. His Optional Accessory Socket Mod makes the Power Outlet live all the time by connecting it to a constant 12V wire behind the secret compartment. You could tap that wire.
I use this mod to trickle charge/condition my battery from a roof top charger.
Old Nov 22, 2004 | 04:20 PM
fmah's Avatar
Look for the mod that prevents the trunk switch from being active when the ignition isn't on. When you make that mod, it switches the power to the trunk switch from one that is active all of the time to one that is ignition switch activated. In other words, use the power to the trunk switch in the glove box.
Old Nov 22, 2004 | 05:25 PM
AusS2000's Avatar
Or just use the link above.
Ed'sS2000
Nov 9, 2014 08:00 PM
Needsmorepower!
Sep 4, 2014 06:13 AM
ap1808
May 8, 2012 04:46 PM
I<3myap1
Oct 28, 2010 05:38 PM
Nachi
Mar 14, 2005 09:46 PM
