V1 Stealth mount
Old Jun 21, 2007 | 09:16 AM
  #31
WLAURENT's Avatar
I am gonna send you some Windex to clean that window man.
Old Jun 21, 2007 | 10:07 AM
  #32
tukluc's Avatar
You are right...you can barely see it from the front
I think I might try this on my own....at least mounting it into the light location without the stealth cover....that will take more practice and knowhow in terms of working with plexiglass...etc.
And advice you can give to help for the radar mount would be greatly appreciated!
Old Jun 21, 2007 | 10:11 AM
  #33
HARDtoTOP's Avatar
I used a dremel with a cutoff wheel to make clearance for the V1 in the plastic area that it is mounted. It is fairly easy once you get the light off. Just place the V1 in the opening and mark where you need to cut. You can look at the first pic in my first post for reference. Only take off what you need to. Cut a little, test fit, repeat. Better to take off too little tahn too much!!
Old Jun 21, 2007 | 12:01 PM
  #34
tukluc's Avatar
Sounds easy enough....how did you physically attach the detector to the light housing? Tape? Screw?
Old Jun 21, 2007 | 03:33 PM
  #35
HARDtoTOP's Avatar
I cut it just right so that it is pressure fit.
ScottsS2k
Feb 25, 2010 05:51 AM
Hiroprotaganist
May 15, 2008 02:53 PM
TODDS 2000
Dec 26, 2007 01:23 PM
Rick Hesel
Apr 27, 2004 09:09 AM
