Vibrating Panel
Old Mar 28, 2009 | 08:34 AM
jemmie's Avatar
Default Vibrating Panel
I installed a Rockford Fosgate T400-4 with Polk MOMO10" subwoofer in custom enclosure, etc. It sounds absolutely amazing except there's a panel that's vibrating when the subwoofer is at certain frequencies.
The panel is the one behind the seats just below where the roof connects to something - it's the rear panel of the area where the roof folds down into. The problem is that I can't figure out how to get the panel off and I don't want to risk cracking/breaking something as it seems like the panel is made of hard, almost brittle plastic. How do I get the panel off to add some soft insulation so it stops vibrating?
Any help will be appreciated. Thanks.
Old Mar 28, 2009 | 10:42 AM
CKit's Avatar
People have removed the soft top tray or covered it with dynamat. Moving to Electronics subforum.
Old Mar 28, 2009 | 03:08 PM
jemmie's Avatar
So how to remove it? How is it secured?
Old Mar 28, 2009 | 06:53 PM
DFWs2k's Avatar
there are a lot of little .... tabs i guess? you have to depress the middle, and then you can pull out the whole "tab"... do that all the way around and then you can remove the soft-top "tray"
damn_son_s2k
Nov 5, 2011 05:29 PM
mrbond413
Oct 1, 2010 04:31 PM
hondakondriak
Mar 5, 2009 08:35 AM
Dr Strangeglove
Feb 5, 2009 08:45 AM
imagine
Jun 2, 2007 07:55 AM
