Will this speaker fit my car .. kappa 652.7i
I know the s2k has 6.5" ...
and according to the infinity kapper 652.7i user manual, it is 165mm which should be 6.5" ... but in many site it said this speaker is actually 6.75" .. or some said oversided 6.5" ..
i have bought these already... anyone knows if these will fit my s2k front speaker?
6-3/4" (Oversized 6-1/2")
Design 2-way
Tweeter Design Dome
Tweeter Composition M.M.D.
Woofer Composition Woven Glass Fiber
Woofer Surround Rubber
Peak Power Handling 225 watts
RMS Power Handling 75 watts
Sensitivity 95 dB
Frequency Response 45 - 25000 Hz
Impedance (per voice coil) 2 ohms
Top Mount Depth 2-1/4"
Bottom-mount depth N/A
Cutout Dimensions 5-5/8
Warranty 3-year Sonic Electronix
Originally Posted by DFWs2k,Mar 28 2009, 06:36 PM
652.7i? why did you buy those? don't you need speakers that have a separate tweeter and woofer?
so it is not going to work ??? .... obviously ... i am not an expert in audio stuff ...
you can probably get a spacer, which will offset it from the door, then you will drill the speaker through the spacer into the door, and the angle will be enough for the magnet to fit into the rest of the door....
BUT
don't you have a tweeter higher up in your door? if you use what you have (the 625.7i), i don't think you'll have as good of a soundstage as you are set up for...thought i think mine are fine with everything in the door panels...
BUT
BUT
BUT
the only reason i got them is because they are cheap .... i did not pay much attention or do any research ...
hope it will still work ... or at least fit ..with spacer like you said ...
