viper 791xv install in ap1
Old Apr 27, 2006 | 01:54 AM
Arbeeezy's Avatar
Default viper 791xv install in ap1
Okay, over the weekend I installed a Viper 791xv in my 2003 Honda S2000. Now everything works fine except for two things. Let's start with what I hope is the easier of the two:
1) I hooked up the multiplexed zone trigger of the alarm to my trunk. In the wiring information for my car on on the12volt.com , it says that the trunk pin is the blue/black wire in the 14pin gray plug behind the driver side kick panel. I hooked up the multiplexed zone trigger to this wire however, whenever I open the trunk while the alarm is armed, nothing happens. The alarm doesn't go off and I get no report. Where should I hook up the trigger so the alarm will go off when the trunk is opened?
2) the alarm does not lock or unlock my car! i searched and searched the site and didn't get the answer. I know door locks are a 5 wire type(type c i guess). I know I'm supposed to use the dei 451M relay that comes with the alarm. Now the 451M relay has 5 wires coming out of it but I'm not sure where to hook them up:
here's the wires I am pretty sure about...
blue/black wire - unlock (the yellow/green wire for the driver's side and pink/blue wire for the passenger side)
green/black wire - lock (the pink/black wire from the key module)
i'm not sure about the following 3 wires...
purple/black fused wire - 12V source or ground??
brown/black wire - ??????????
white/black wire - ??????????
Any help will be greatly appreciated! thanks in advance!
Old Apr 27, 2006 | 03:40 AM
MitchSF's Avatar
I'm doing this with a Compustar alarm now. Check the12volt.com for a wiring diagram. You need two SPDT relays unless the Viper controller has them built in.
I don't know what the 451M relay is, but you only need two standard 12v SPDT relays.
Mitch
Old Apr 28, 2006 | 09:34 PM
Arbeeezy's Avatar
Someone please help me figure this out. Everything works with the 791xv on my car except for the darn door locks. I figured out the reason the trunk trigger wasn't working. I know I have to use all 5 wires from the 451 door relay(basically two 5 wire relays built into one) that comes with the alarm. Now here are the 5 wires that come from the 451 and what it says to hook it up to from the12volt.com website:
purple/black(fused) = lock/unlock normally 87 - fused 12V
green/black = lock output #30 - pink/black wire at key module
white/black = lock normally closed 87a - pink/black wire at key module
blue/black = unlock output #30 - yellow/green wire & pink blue wires at key module
brown/black = unlock normally closed 87a - yellow green wire at key module
i used two diagrams from the12volt.com website:
first i used the actuator/reverse polarity diagram because my roommate's co-worker who does the car alarm/stereo installs at best buy said that my car is this type:
Didn't work...kept blowing the keyless entry fuse at the fuse box
Next I used the 5 wire alternating 12V positive door locks diagram:
Still doesn't work. I keep blowing the fuse on the purple/black wire.
Please help. I'm really starting to get frustrated as I am so close yet so far from being done with this install. Like I said, everything works but the darn door locks. Please don't send me a link to the "directwire" wiring information for my car as I have this already. Please don't refer me to the12volt.com website as i've looked through there a million times to no avail. I'm hopefully looking for someone to respond who's actually done this and knows exactly where i need to wire things up to. thanks in advance to anyone who can help me.
Old Apr 28, 2006 | 10:16 PM
revhi's Avatar
Dont know if this helps, but heres DEI's tech sheet.
If you can wait, I can find out on monday what to do at work.
Old Apr 28, 2006 | 10:22 PM
Arbeeezy's Avatar
[QUOTE=revhi,Apr 28 2006, 10:16 PM] Dont know if this helps, but heres DEI's tech sheet.
12volts white (x2) + ignition harness
Starter blue/white + L of column, lt blu 24P plug
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition black/red + ignition harness
Third Ignition N/A
Accessory white/red + ignition harness
Second Accessory N/A
Keysense red/white - ignition harness
Power Lock pink/black 5wi keyless entry module
Notes: The keyless entry module is located in the driver kick behind the start button.
Power Unlock yellow/green & pink/blue 5wi keyless entry module
Lock Motor pink/black 5wi keyless entry module
Unlock Motor yellow/green 5wi keyless entry module
Parking Lights+ red/black + keyless entry module
Parking Lights- blue - headlight switch
Hazards same as turn signals
Turn Signal(L) green/red + steering column
Turn Signal
SlowTeg
Nov 3, 2010 12:16 PM
dia_cero2002
Jul 11, 2006 01:42 PM
MitchSF
Apr 23, 2006 10:55 AM
PhiZzaK_S2K
Feb 28, 2006 07:41 AM
autoconcept
Jan 14, 2001 10:03 AM
