Where can I buy a Low Pass Filter online?
Old Apr 8, 2005 | 11:50 AM
TepEvan's Avatar
Default Where can I buy a Low Pass Filter online?
I'm going to be using my amp in tri-channel mode for short-term and need to get a Low Pass Filter for the sub. Anyone know of a place online that I can purchase one of these?
Thanks in advance!
Old Apr 8, 2005 | 02:52 PM
WLAURENT's Avatar
go here to find the crossover point you want
http://www.apicsllc.com/apics/Misc/filter1.html
Then go here and get your coil
http://www.partsexpress.com/webpage.cfm?&D...&WebPage_ID=309
Typical for a 4 ohm sub is to use a 6 or 7mH coil (around 120-90 Hz Fc)
Old Apr 8, 2005 | 04:30 PM
TepEvan's Avatar
Perfect! Thanks for the good info and links!
Old Apr 8, 2005 | 04:44 PM
TepEvan's Avatar
ok, I'll ask one more question, since I've never incoporated this into any of my previous systems. do i just splice/solder it inline to the positive and it can just hang there (meaning it doesn't need to be truly mounted or anything)? I would obviously "mount" it on my amp rack.
Old Apr 8, 2005 | 06:49 PM
PJK3's Avatar
yeah... it goes inline on the + side of the sub's lead. and it's good. it will be too heavy to literally just hang , so go w/ your plan of mounting it on the amp rack.
it has been a long time since i used one of these, but as i recall it was pretty straight forward.
Old Apr 9, 2005 | 09:13 AM
TepEvan's Avatar
youse guys are the bestest!
Old Apr 9, 2005 | 04:10 PM
PJK3's Avatar
Old Apr 21, 2005 | 05:41 PM
tizbad2k's Avatar
Hmm the chart on that page is not accurate at all.
Assuming that For every -3db you will lose 50% of the signal. I ran some simulations with inductors of the size the reccomended and found that their cutoff frequencies were very wrong.
For example with a .25mH and 8 ohm load it says your cutoff frequncy is 5k but actually -3db occurs at 8.8k. And then it says a 1.27mH inductor with a 8 ohm load will give you cutoff at 1k but it actually give you half your input at 1.7k.
So unless im missing somthing that chart is completely wrong.
thqs2k
Apr 22, 2009 07:51 AM
Penforhire
Aug 12, 2008 07:52 PM
tangelina
Nov 24, 2006 10:10 AM
xjohnx
Jun 14, 2004 08:25 AM
AirWolf
Apr 9, 2002 06:06 AM
