Wired Mute Inop w/IR DCI and 9856
I just installed my new Alpine CDA-9856 with Modifry IR-DCI (great product!). Everything works as it should with the exception of the wired mute feature (DCI blue wire) interfaced to the Alpine pink/black interrupt wire.
I triple checked that the proper wires are connected and the connection itself is good (solder and shrink...I know someone will suspect a butt splice
). When DCI Switch 3 (defeat IR Mute) is set to off, the mute function does not work, although the mute wires are connected and the function is enabled in the 9856 (it's a menu item in Setup).
This is not really a problem for me as I went ahead and reenabled the IR Mute. Not pausing the the CD per the hard wire mute is no big deal. I just wanted to report in since the 9856 is still fiarly new and this might be an issue. Otherwise, having a great time with the new setup!
Johnson Knowles
). When DCI Switch 3 (defeat IR Mute) is set to off, the mute function does not work, although the mute wires are connected and the function is enabled in the 9856 (it's a menu item in Setup). This is not really a problem for me as I went ahead and reenabled the IR Mute. Not pausing the the CD per the hard wire mute is no big deal. I just wanted to report in since the 9856 is still fiarly new and this might be an issue. Otherwise, having a great time with the new setup!
Johnson Knowles
