wiring question alpine deck to honda harness
Old Apr 14, 2007 | 04:26 PM
BowlofRice's Avatar
Default wiring question alpine deck to honda harness
sorry i couldn't find it in a search... at least, i'm not gettign the search right. at any rate I pulled out the amp that the previous owner used and now i'm left with the blue and blue/white wire that i don't know what to do with.
2 Power Antenna Lead (Blue)
Connect this lead to the +B terminal of your power antenna,
if applicable.
NOTE
This lead should be used only for controlling the vehicle's power
antenna. Do not use this lead to turn on an amplifier or a signal
processor, etc.
3 Remote Turn-On Lead (Blue/White)
Connect this lead to the remote turn-on lead of your
amplifier or signal processor.
i've read that i need to connect the blue/white to something to make the amplified antenna work. so any clue which wire in the honda harness to connect to? or is it a ground?
Old Apr 14, 2007 | 04:48 PM
imdarkrider's Avatar
connect the blue wire , the blue wire is only sending out 3amps of power when the radio is on , when the cd or another source is on it doesn't send out power. Hense using blue/white which is on when the radio is on for amps. Do not hook any of these wires to ground
Old Apr 14, 2007 | 06:50 PM
BowlofRice's Avatar
so what do i connect the blue/white wire to? there isn't a corresponding wire in the alpine harness. do i directly connect it to the honda harness?
Old Apr 14, 2007 | 07:49 PM
if there's no blue wire in the alpine harness but there's a blue one on the honda plug then connect that to the blue/white wire otherwise you don't need to connect it to anything. just tape it off
Old Apr 15, 2007 | 12:01 AM
BowlofRice's Avatar
theres a blue and blue/white wire on the alpine harness but none on the honda harness.
Old Apr 15, 2007 | 06:52 AM
then tape them both off...
Old Apr 15, 2007 | 07:01 AM
itsmylittlebrothersbike's Avatar
The blue/whit wire from Alpine in the remote turn on lead wire. This is normally used to turn on the amplifier when the head unit is powered on. If you dont need it, then tape it off.
Old Apr 15, 2007 | 10:03 AM
BowlofRice's Avatar
alright thanks for all the help guys!
Old Apr 15, 2007 | 02:25 PM
good luck!
Reckon
Jan 9, 2015 07:32 PM
S2K 4 ME
May 18, 2008 12:28 PM
AmazingGinsu
Apr 17, 2007 03:26 AM
BowlofRice
Dec 26, 2006 05:53 PM
