Wlaurent Stelth Sub Enclosure question.
Old Jun 9, 2003 | 05:57 AM
PJK3's Avatar
looks like your amp is 2 ohm stable on the sub channel. like William said, that is not suprising since it probably uses a class D amp for the sub section. looks like your continuous power for the sub is around 150Wrms at 14.4V, so choose 4 ohm sub(s) that are rated to handle power in that range... (125Wrms - 200Wrms is a good range to work in...)
you're more than capable of running 2 subs off this amp. just make sure you buy subs that are rated for a 4 ohm load...
(if you choose to buy a DVC (dual voice coil) sub, you could probably get a 2 ohm DVC sub and wire the voice coils in series to get the sub to present a total 4 ohm load to the amp...)
best of luck w/ the system install...
i put (what i hope are) the final touches on mine this weekend... so once i borrow a dig. cam, i'll be posting some shots... with some luck, you'll find them helpful... best of luck and keep us updated!
Old Jun 9, 2003 | 06:11 AM
ruexp67's Avatar
Cool, thanks for the help with this. Can't wait to see your pix.
BTW -- I have been taking pix as I go so I will be able to do a full write-up.
Apex_AP1
Mar 2, 2008 08:44 AM
Apex_AP1
Feb 29, 2008 05:21 AM
Brutewes
May 16, 2006 01:14 PM
DFWs2k
Mar 11, 2006 09:02 PM
Hickey322
May 29, 2003 09:52 PM
