AEM EMS
Hey everyone, I have been having a huge issue with my car. I recently Data logged a few runs with it acting up and not acting up and I have no idea what to look for... I've never really messed around with the EMS.
I was wondering if someone could take a look at some of the logs that I have and see if they can find anything wrong and see why I'm having the issues that I am.
Here's a link to the thread describing my problem:
https://www.s2ki.com/s2000/topic/898...#entry20992331
Thanks in advance,
Robert
Thanks in advance,
Robert
It sounds like you're running on three cylinders. That would also be why you're running leaner than usual. First thing I would recommend doing is a spark test. Make sure each coil is firing.
Is there a reason why it's only when the car heats up and started back up after it's warm?
I read somewhere that when it gets warm the coilpacks contact point might expand, but I just wonder why it doesn't do it on the first start after it gets warm.
So I thought I had the issue resolved. I swapped out my coil packs with another members and the car ran fine for 3 solid runs and then I had to go to work. I ordered 4 used coil packs and swapped them out and was still having issues. I have isolated the problem to the one closest to the firewall (cylinder 4). Well whenever I put a "cold" coil in the car runs fine for a little while and then starts acting up again. I bought a new one from the store and it too fails when it hits a certain temp. I've interchanged 6 different coils all with the same result. It runs fine until it gets hot.
Anyone have any input?
I swapped out the manifold a couple days before this started happening, but it's pretty much the same. I wrapped the downpipe with a heatwrap and I'm not sure how to combat the rest of the heat unless I vent or get a vented hood. I'll try insulating the wiring somehow.
I'm going to try and take logs of when it's acting up because the last time I did the car decided to run fine and I have 3 good runs and no bad ones. It's also weird that the weather is actually much colder now then the day that it ran fine.
