AEM EMS
Old Nov 7, 2011 | 10:54 AM
Gators2kt's Avatar
Default AEM EMS
Hey everyone, I have been having a huge issue with my car. I recently Data logged a few runs with it acting up and not acting up and I have no idea what to look for... I've never really messed around with the EMS.
I was wondering if someone could take a look at some of the logs that I have and see if they can find anything wrong and see why I'm having the issues that I am.
Here's a link to the thread describing my problem:
https://www.s2ki.com/s2000/topic/898...#entry20992331
Thanks in advance,
Robert
Old Nov 8, 2011 | 07:04 AM
Gators2kt's Avatar
Bump.
Old Nov 11, 2011 | 12:25 PM
InductionPerformance's Avatar
It sounds like you're running on three cylinders. That would also be why you're running leaner than usual. First thing I would recommend doing is a spark test. Make sure each coil is firing.
Old Nov 12, 2011 | 12:28 PM
Gators2kt's Avatar
Is there a reason why it's only when the car heats up and started back up after it's warm?
I read somewhere that when it gets warm the coilpacks contact point might expand, but I just wonder why it doesn't do it on the first start after it gets warm.
Old Dec 8, 2011 | 08:29 PM
Gators2kt's Avatar
So I thought I had the issue resolved. I swapped out my coil packs with another members and the car ran fine for 3 solid runs and then I had to go to work. I ordered 4 used coil packs and swapped them out and was still having issues. I have isolated the problem to the one closest to the firewall (cylinder 4). Well whenever I put a "cold" coil in the car runs fine for a little while and then starts acting up again. I bought a new one from the store and it too fails when it hits a certain temp. I've interchanged 6 different coils all with the same result. It runs fine until it gets hot.
Anyone have any input?
Old Dec 8, 2011 | 10:55 PM
TTMartin's Avatar
Too much heat from your turbo?
Address the excessive heat under the hood?
Bad wire/connection that acts up when hot?
Old Dec 9, 2011 | 05:56 AM
Gators2kt's Avatar
I swapped out the manifold a couple days before this started happening, but it's pretty much the same. I wrapped the downpipe with a heatwrap and I'm not sure how to combat the rest of the heat unless I vent or get a vented hood. I'll try insulating the wiring somehow.
I'm going to try and take logs of when it's acting up because the last time I did the car decided to run fine and I have 3 good runs and no bad ones. It's also weird that the weather is actually much colder now then the day that it ran fine.
Old Jan 12, 2012 | 10:57 AM
Gators2kt's Avatar
Another member mentioned that the tune may be messed up. Apparently he was having a similar issue and it turned out to be the low load below 4k rpm which is basically where my car is at it's worst.
HoustonNFR
Apr 8, 2012 05:28 AM
HoustonNFR
Apr 7, 2012 08:52 PM
S2k.berto
Mar 3, 2011 10:00 PM
menacejean
Feb 2, 2011 10:24 AM
beroznikmal
Nov 2, 2004 09:50 AM
