AEM EMS Temp guage question
Old Jun 10, 2011 | 09:52 AM
jdmdohcpower's Avatar
Default AEM EMS Temp guage question
Hey guys Recently my stock coolant temp gauge that Im aware is no longer functioning has gone from the normal 1 bar that it showed since tuning with EMS, to full hot all bars and the red. Should I be concerned? Any thoughts? Did some searching but have found nothing like this.
So to sum, for 2 years after Jeff Evans did AEM EMS the stock temp guage sat at 1 bar, now out of nowhere its full hot all the time...
Any help would be great
PS,
the car's collant temp is normal
Thx
Old Jul 12, 2011 | 08:12 AM
jh4db536's Avatar
I feel the water temp reading is more accurate than stock with the ems. I think the stock ecu overrides the temp sensor for the first minute, because now my temp sensor jumps to 2/3 within twenty seconds from a cold start (head heating up rapidly with the air pump and the thermostat is closed). then goes normal once the thermostat opens and coolant from the radiator stars flowing
Sent from my T-Mobile G2 using Tapatalk
Old Jul 23, 2011 | 02:07 AM
SOHCmyDOHC's Avatar
if you have the first series EMS, the factory gauge will no function properly unless you have bought the modifry temp fix.
Old Jul 23, 2011 | 05:13 AM
S2johnyK's Avatar
http://forum.aempowe...p?topic=27209.0
erikvanden
Sep 6, 2011 05:26 PM
jdmdohcpower
Jun 13, 2011 07:28 AM
SpyderS2K
Aug 13, 2007 05:01 PM
mimime77
Nov 3, 2006 03:26 PM
nsxinsac
Jun 4, 2005 09:49 AM
