Fans aren't going on
Old Sep 6, 2011 | 07:07 AM
erikvanden's Avatar
Default Fans aren't going on
I have an FI setup with an AEM EMS and I don't think my rad fans are turning on. I replaced the stock fans with slim fans but kept the same wiring. They turn on fine when I put the AC on but otherwise I don't think they go on. The tuner thought there may be an issue when I last brought it in. The only thing I can think of is that I have not yet bought the modifry temp gauge fix. I don't know how they worked before I put the AEM EMS in, but the temp gauge already read middle bar before then after it warmed up. Never more or less.
Old Sep 6, 2011 | 07:29 AM
9krevvin's Avatar
Your coolant temperature sensor could be bad. It may not see that the temperature is getting hot enough to turn the fans on. The fans always turn on when the a/c is on to cool the condenser. Are both fans turning on with the a/c on?
Old Sep 6, 2011 | 08:23 AM
LINESUPER's Avatar
Stock fan switch turns fans on at 190 deg and off at 180. I just checked this out on my S yesterday. do you have series 1 or series 2 AEM ECU? It will not make any difference on when fans start, but series one will only dispay one bar on the display.
Old Sep 6, 2011 | 11:33 AM
Deception's Avatar
you sure about that? I ran an OBD2 scan tool for a while when the car was NA, rad fan came on at 205 degrees like clockwork. 00' ECU
Old Sep 6, 2011 | 11:41 AM
InductionPerformance's Avatar
Are you running a Version 1 or Series 2?
Old Sep 6, 2011 | 11:51 AM
Spec_Ops2087's Avatar
Correct stock fans turn on at ~205 and off around ~195
Old Sep 6, 2011 | 03:30 PM
erikvanden's Avatar
I have series one AEM EMS. I don't really want to put the ac on when im driving just to have the fans come on. I have been thinking of wiring them so they are always on.
Old Sep 6, 2011 | 04:26 PM
LINESUPER's Avatar
Originally Posted by Spec_Ops2087
Originally Posted by Deception' timestamp='1315337610' post='20948086
[quote name='LINESUPER' timestamp='1315326222' post='20947354']
[/quote]
We are both wrong - turn on at 93 deg C or 199.4 deg F - guess my new gauges have some lag in showing correct temp. but they dropped of line after 10 deg drop in engine temp.
Old Sep 6, 2011 | 04:51 PM
Deception's Avatar
Originally Posted by Spec_Ops2087' timestamp='1315338663' post='20948158
[quote name='Deception' timestamp='1315337610' post='20948086']
[/quote]
[/quote]
you sure it wasnt 199.4355 deg ? 199.4 seems a little low
Old Sep 6, 2011 | 05:26 PM
E-mail me your calibration and I will make the needed adjustments you most likely need for the fans to come on
Tuning (at) InductionPerformance (dot) com
jdmdohcpower
Jul 23, 2011 05:13 AM
jdmdohcpower
Jun 13, 2011 07:28 AM
SpyderS2K
Aug 13, 2007 05:01 PM
mimime77
Nov 3, 2006 03:26 PM
nsxinsac
Jun 4, 2005 09:49 AM
