AEM Infinity
I just ordered the Infinity so I'm looking forward to the gains. The tuning shop I'm taking it to says they've worked with AEM ECUs before and they say it's a massive PITA. Hopefully this one will change their minds.
Originally Posted by mLeach' timestamp='1414601474' post='23386953
Wadzii/others,
Do you think that it is possible to effectively run a "street" NA f20c, using the PNP harness, and only the factory sensors, or does it require the additional sensors to work?
If you'd to share this information offline, please email me: matthew[d0t]leach[attttatatat]gmail.com - I need some data for an SCCA rules discussion.
Thanks,
Matt
Thanks,
Matt
Since the infinity does base its calculations on fuel pressure its important to have a fuel pressure gauge and a steady fuel pressure if you are not going to add a sensor. The new 300+ lph fuel pumps overload the stock regulator at low duty cycle and will make tuning a little more difficult if you dont have the fuel pressure sensor.
Really? None of the AEM v1/v2/Infinity ecu's are a "PITA" or even all that complex. The V1 is kind of clunky due to the desktop software, but the V2 & Infinity are amazing and a blast to work with.
Originally Posted by wadzii' timestamp='1414690893' post='23388239
[quote name='mLeach' timestamp='1414601474' post='23386953']
Wadzii/others,
Thanks,
Matt
Wadzii/others,
Thanks,
Matt
[/quote]
A fuel pressure sensor and regulator are not required as a static fuel pressure can be used instead on the Infinity.
However, the Infinity will not be able to make injector pulse width changes based on fuel pressure fluctuations/loss if you don't use a fuel pressure sensor.
Originally Posted by schhim' timestamp='1415077772' post='23392834
[quote name='wadzii' timestamp='1414690893' post='23388239']
Wadzii/others,
Thanks,
Matt
Wadzii/others,
Thanks,
Matt
[/quote]
[/quote]
Thanks for the explanation, even if I don't understand what any of that means.
I got it in the mail the other day and I'm so tempted to install it myself but I don't want to futz it up or run a base tune right before I hit the Dragon.
Originally Posted by TheCarGuy2021' timestamp='1415312608' post='23396285
[quote name='schhim' timestamp='1415077772' post='23392834']
Wadzii/others,
Thanks,
Matt
Wadzii/others,
Thanks,
Matt
[/quote]
[/quote]
[/quote]
Simple answer: You can just punch in your known fuel pressure to the Infinity software and not worry about adding a sensor. You have the option of adding a sensor if you want ultimate safety/control.
Finally getting it installed. Found a reputable tuner who's AEM trained. I did a baseline tune and it put down a respectable 214 at the wheels on a Dyno Dynamics. I'm still N/A w/ a Berk HFC and Super Sprint exhaust. Hoping to see some good gains with it. I'll pick it up in about 3 weeks and let y'all know the results.
