AEM Infinity
Old Dec 18, 2014 | 03:30 AM
  #61
wadzii's Avatar
Banned
Slow starting in a civic is just bad tuning.
In the op's case it sounds weird. I haven't had any issues as at all with startup. I'm surprised the shop that did the install didn't warranty that for you. No way I'd let a car leave the shop like that.
If you connect your computer to the ecu in the diagnostics tab there is a parameter called start probability. If the car doesn't start when that hits 100 there is usually a problem in the tune.
Old Dec 18, 2014 | 07:39 AM
  #62
TheCarGuy2021's Avatar
schhim,
It sounds like you may have some tuning issues that need to be sorted out. It could be a number of things but cruising around at low speeds with brief power cuts at low throttle sounds like your decel fuel cut could be activating. Under no circumstances should you need to crank the engine more than once for it to fire up. Is this shop AEM Infinity factory trained?
Feel free to shoot me a PM, I'd love to help you resolve any issues you may have.
Old Dec 18, 2014 | 10:24 PM
  #63
VitViper's Avatar
Originally Posted by schhim
So here's my update after picking up the car and driving it for myself for over an hour on my way home. First, the shop told me that it may not start on the first or even third crank because the car isn't communicating with the ECU. They went over the start up settings and everything and think that it may be a relay in the harness. Sure enough, I tried starting it and it didn't start until the 4th time. I called the vendor and they're going to get a hold of AEM to see if I can get a replacement.
We have a couple Infinity's on S2K's and not a single one has that cranking issue. Sounds like you need to look into the VR configuration for the cam/crank pick up at low engine speed, and/or the actual starting fuel/ignition/ve tables need to be tuned. My personal S2K fires up first try on E85 with 30* ambient temps on 1500cc injectors.
Old Dec 19, 2014 | 04:08 PM
  #64
av8ter's Avatar
Is it worth the $1600 for 10 hp?
Where did you get it for $1600?
Old Dec 19, 2014 | 06:03 PM
  #65
schhim's Avatar
Moddiction.com. Use coupon code AEM.
Old Dec 20, 2014 | 09:10 AM
  #66
Spooked25's Avatar
I just took the plunge as well. I get my infinity next week. Then to install a bunch of stuff. After that. Off to a tuner. Anyone have a map I could use with 550 injectors ? Or do I just set the VE+target AFR stuff and it will allow me to drive to the tuner ?
Old Dec 20, 2014 | 03:48 PM
  #67
deuce_s2k's Avatar
Originally Posted by wadzii
There is no good reason to run a v2 over an infinity. Infinity is more than proven. Its been in use for a few years now.
If you don't have use for the factory harness then I'd recommend building a new harness that plugs directly into the infinity with out the jumper
GOT MY INFINITY TODAY, THANKS AGAIN.
Old Dec 22, 2014 | 02:12 PM
  #68
schhim's Avatar
Of the folks who bought the Infinity, how many of y'all are NA?
Old Dec 23, 2014 | 09:35 AM
  #69
Spooked25's Avatar
I am running a GReddy turbo kit.
Old Jan 2, 2015 | 08:15 AM
  #70
06Estukay's Avatar
I ordered an Infinity 6 for my '06. Will be running a custom harness, and converting to cable throttle. I am NA, with a fully built motor. Going to be installing Urge's new Elliptical AT Power itb's. Will provide updates over the winter.
