AEM Infinity
Old Jan 2, 2015 | 10:20 AM
  #71
schhim's Avatar
Originally Posted by 06Estukay
I ordered an Infinity 6 for my '06. Will be running a custom harness, and converting to cable throttle. I am NA, with a fully built motor. Going to be installing Urge's new Elliptical AT Power itb's. Will provide updates over the winter.
We may have to compare notes on our tunes. I'm taking my car back to the tuner and having him work with TheCarGuy to refine the tune. It looks like some of the settings on the base map need to be tweaked so I'll let you know that your tuner should thoroughly go over all the settings. Good luck!
Old Jan 2, 2015 | 10:45 PM
  #72
copmagnet82's Avatar
Are you making your own custom harness or having someone do it for you?
Old Jan 15, 2015 | 05:55 AM
  #73
ino20's Avatar
I figured i'd join in on this conversation, i am also infinity running the new doc race turbo kit, DPI injectors, gtx35 to summarize it. This will be a time attack car and im on a budget so blowing up engines is not an option. I'll keep you guys updated on numbers
Old Jan 20, 2015 | 07:30 AM
  #74
06Estukay's Avatar
Someone made it for me per my specs and pinout/schematic.
Old Jan 25, 2015 | 09:10 AM
  #75
av8ter's Avatar
Anyone know where to get the correct connector(male) to plug into the PNP's Lambda connector? Not sure if it was supposed to come with one or not but I am having a hell of a time trying to figure out where to buy one. Don't really feel like chopping up a brand new harness.
Old Jan 25, 2015 | 09:19 AM
  #76
wadzii's Avatar
Banned
Aem sells the o2 harness separately. 30-3600. We have them in stock
Old Jan 25, 2015 | 10:16 AM
  #77
av8ter's Avatar
Thanks for the info. $83 on amazon? I'm going to get to hacking unless you can do 1/4th of that price.
Old Jan 25, 2015 | 10:29 AM
  #78
wadzii's Avatar
Banned
The lsu4.2 connector is around $20-25 by itself and they use high end DTM connectors and high end wire. If we could build something of equal quality cheaper we would. You can build it out of cheaper things if you want. I can get you the connectors if you want to build your own.
Old Jan 25, 2015 | 11:25 AM
  #79
av8ter's Avatar
http://www.jegs.com/i/AEM/017/35-340...0EIxoCUHjw_wcB
Really high dollar. Only thing missing is some sleeving and a $2 connector.
Old Jan 26, 2015 | 05:23 PM
  #80
VitViper's Avatar
Wrong harness.
