AEM Serial Gauge Calibrations
Old Nov 2, 2012 | 04:44 AM
E4RTH WORM JIM's Avatar
Default AEM Serial Gauge Calibrations
Hi,
I've installed a serial gauge into my CT supercharged S2000 but I'm having a nightmare getting it to read correctly.
All my sensors are out of calibration so I need some help.
I've downloaded AEM tuner, connected to my laptop, selected Wizards, Setup wizard, telemetry, and 'matched' my serial gauge.
I've also downloaded Progauge and connected to the serial gauge.
The problem is I'm unsure of what values to put in when using the 'auto fill' feature under 'look up table' tab (Progauge).
Here is a screen shot of my sensor values off the EMS (AEM V2)
Now here's a shot of Progauge look up table for AIT:
What values should go in the top left boxes (Start cell & End cell) to make the unit function correctly, I've try everything I can think off???!
I can't get Boost/load, AIT and Coolant temp to read right no matter what I do.
Thanks
Old Nov 10, 2012 | 03:15 PM
Wydget's Avatar
I don't have a good working knowledge of the software enough to explain it but I do have my calibration file that has boost, ait and coolant temp working if you'd like to look at the file and see what is different in yours. If you send me your email, I'll send it to you.
E4RTH WORM JIM
Nov 5, 2012 03:03 PM
jordannn93
Mar 18, 2012 08:16 AM
TelosHedge
Aug 18, 2009 08:38 PM
maluch
Jul 28, 2008 05:34 AM
kleecker
May 17, 2007 12:45 PM
