AEM V2 Limiters
Old Dec 4, 2011 | 08:10 PM
ummpwr's Avatar
Default AEM V2 Limiters
Hello, I would just like a little input on my limiters set up.
I have a 00 ap1, AEMV2, comptech s/c novi 1220, 3.4in SOS pulley, 750cc inj, 255 pump, berk header/test pipe,
I had my car tuned after the s/c install and just did some data logging to see exactly where I am.
my limiters are
MAIN
Fuel cut load 15.0 psig
Fuel cut 9500
Ignition cut 9200
Retard Limit rev 12000
2 step limits
2 step max vss 5
2 step fuel cut 4700
2 step ignition cut 4500
2 step retard limit rev 12000
@ 9200rpms
engine load(boost)14.68
0 Knock
11.2afr
87.8 injector duty cycle
So on my logs in 2nd gear I hit up to 9330rpms Should I lower my main limiters 100rpms or am I safe? Also how are my 2 step limits? I have not used 2 step yet
Thanks, Eric
Old Dec 4, 2011 | 09:18 PM
DFWs2k's Avatar
Stock or built head?
Sent using free Tapatalk - Android FTW
Old Dec 5, 2011 | 04:59 AM
ummpwr's Avatar
Stock engine
Old Dec 5, 2011 | 06:10 AM
s2knoob89's Avatar
If your hitting 9330rpm in 2nd with your setting you should be bouncing off the limiter. It's safe, don't worry about it.
Old Dec 5, 2011 | 06:35 AM
ummpwr's Avatar
yes 9330 is when its bouncing of the limiter, I just wanted to know if that is a safe range for the f20c or if I should lower it by 100rpms or so?
Thanks, Eric
nMeOnE
Jul 5, 2016 08:14 AM
dan_uk
Oct 4, 2014 01:35 PM
s2konroids
Feb 15, 2014 01:07 PM
boony1968
Oct 15, 2013 04:27 AM
s2000Junky
Sep 24, 2008 12:09 PM
