Apexi VAFC and Rev limiter
Old Jul 12, 2016 | 05:19 PM
deanob's Avatar
Default Apexi VAFC and Rev limiter
Hi guys quick question. Figured I'd post this since it's about the apexi VAFC which is so old data is hard to find. So I'm hoping someone with experience can chime in.
I have an ap2 motor in my ap1 with an ap1 ecu and I installed the VAFC just so I can set the Rev limiter lower but now I'm not even sure if this thing can do it. Anyone know if it can or am I stuck having to find a VAFC2 or Neo?
Thanks
Old Jul 12, 2016 | 05:48 PM
zeroptzero's Avatar
I don't recall any VAFC (1,2 or Neo) being capable of affecting rev limits, only VTEC setting and air-fuel adjustments.
Old Jul 12, 2016 | 06:55 PM
s2000Junky's Avatar
None of the vafc or neo units can adjust rev limit. The neo is by far better then the previous 2 though because you can set vtec engagement to come on not just by rpm but throttle %, so you can set vtec low/3500-3700 rpm where the f22 responds well. You will be cruising in vtec at that rpm with the other units which sucks. But back to rev limit, best you can do is get a shift beeper and let the ap1 ecu run rich after 8500rpm, so no fuel cutting after this say 13afr at 8500rpm and then 8600rpm + it drops to 11.x, and you will feel the power drop off pretty abruptly (which the f22 does anyway) but this is also safer high rpm tune anyway and combined with motor out of breath and running rich combined, you will best be able to feel when to shift. I run an f22 with an ap1 ecu and this is how I set mine up. I had a beeper but disconnected it because it was loud and felt I didn't need it after tuning. I never hit the rev limiter with this motor, but it will take it if you do, just wouldn't amke a habit out of it, because it will shorten the overall life. 8500-8600rpm is a good limit.
Old Jan 16, 2017 | 11:24 AM
C4vettrn's Avatar
If I purchase a Neo for MY02, is this something the ley person can figure out? Does the Neo give you the needed data or will I need a program for my laptop i.e. Datamaster, etc.? Just wanting to lower the Vtec some but worried about screwing up the AFR settings. I have a TP and doing the UK mod, and K&N CAI.
Would this require a wideband O2 ? The testpipe was on when I purchased it and there are no cells so I am unsure how it was configured for this mod.
Old Jan 16, 2017 | 11:50 AM
s2000Junky's Avatar
You don't need a laptop, since the vafc/neo programming is all interfaced. I highly recommend you install a wideband afr gauge though or you have no idea if your too lean or not. When you lower vtec your ecu still thinks/supply's primary cam fuel tables. In some circumstances its (stock ap1) not too lean, but after a couple breathing mods and typically with f22 engines it can be, so you need to see this and adjust accordingly, either by not lowering vtec as low in the rpms as you could otherwise, or better adding a mechanical adjustable fuel pressure regulator to dial in more fuel there, then trim back the fuel via the vafc/neo in the bottom and top end of the rpms. You will get a safer and better performing tune if you follow my recommendation here for the vafc/neo road.
Old Jan 18, 2017 | 11:11 AM
C4vettrn's Avatar
Will I need a Boomslang or Frog adapter to connect to ECU?
Old Jan 18, 2017 | 12:55 PM
Aurex's Avatar
You don't, but it does make the install easier and easier to change back to stock. the wires on both the ECU and NEO/VAFC are small and difficult to work with.
FWIW, I hard wired mine but I have no intent to modify the car to the point that I need a standalone ECU.
Old Jan 18, 2017 | 09:24 PM
s2000Junky's Avatar
pnp is also a no brainer for troubleshooting issues in the future, and certainly if you end up messing up the install/hack job initially. Will save you a lot of time and frustration. I would never recommend spicing in with the amount of wires involved just to save $150.
CHUCKIE
38
Feb 20, 2004 02:36 PM
ItalianBucwheat
May 21, 2003 10:28 AM
quicsvr
Aug 30, 2002 08:58 AM
dtms
May 31, 2002 06:22 PM
Cyber Logic
Feb 7, 2002 01:03 PM
