Car is not hitting redline.
Old Aug 5, 2011 | 12:06 AM
vadik_s2k's Avatar
Default Car is not hitting redline.
So the quick question - redline is set at 8500rpm in flashpro but maximum I've seen in logs is like 8250-8350, is there any explanation for this? I logged with flashpro set at fastest log rate...will very appreciate if someone could advise is it normal or not..
Old Aug 5, 2011 | 10:43 AM
Gernby's Avatar
Former Sponsor
I think the easy explanation is that you are lifting your foot off the throttle before getting to 8500.
Old Aug 6, 2011 | 12:51 PM
vadik_s2k's Avatar
Well I hit the pedal till the ecu cuts fuel/throttle...
Old Aug 6, 2011 | 11:02 PM
H22toF20's Avatar
Then I'd imagine that your timing cut is sooner than your desired limiter.
Old Aug 8, 2011 | 10:15 AM
vadik_s2k's Avatar
That could be the reason since the car is still being tuned by Evans Tuning...
Dan1987
Apr 25, 2011 12:27 AM
jb34304
Oct 18, 2010 12:39 PM
Sinco06
May 16, 2007 03:19 AM
Pinky
Apr 17, 2003 09:40 AM
krazik
Feb 22, 2002 09:19 PM
