ELD Wire
Old Oct 18, 2012 | 10:39 PM
RedSunS2K's Avatar
Default ELD Wire
Can anyone confirm that this is the ELD wire A30? This connector is the closest to you when looking at the ECU. The wire is green and red. Thanks.
Old Oct 22, 2012 | 08:59 AM
5810ap1's Avatar
yes... first connector near hood release ---a30...thats what used for wideband hook up.. i would verify color but im color blind lol.
Old Nov 5, 2012 | 11:32 AM
liquidgsr's Avatar
Thats the one I spliced into, but its in a different place on my 07.
Old Nov 5, 2012 | 12:24 PM
RedSunS2K's Avatar
Where do you guys splice the ground wire for your widebands?
Old Nov 6, 2012 | 09:38 AM
spectacle's Avatar
Put a ring terminal on the ground wire and use one of the bolts next to the hood latch release. The wideband doesn't need to share a ground with the ECU.
Old Nov 11, 2012 | 03:55 PM
liquid_helix136's Avatar
This. Seriously. I've done the ground on my wideband a couple different ways, and all of them resulted in a 'travelling ground' which basically means that the voltage varies slightly, so my wideband would be on sync sometimes and then sometimes be .2-.3 off. I changed the ground to one of the bolts like spectacle is talking about and that issue went away.
Old Dec 2, 2012 | 12:17 PM
hybridsol's Avatar
Spec-
Can you verify you had to remove some resistors on-board with the Kpro to get the PLX wideband to read below ~11.5?
(Appologies to OP for thread jacking)
Hondata link
Thanks!
Old Dec 3, 2012 | 07:10 AM
spectacle's Avatar
Originally Posted by hybridsol
Spec-
Hondata link
Thanks!
Yes I can verify. This has been verified to apply to the ELD wire...if you use one of the analog inputs (KPro 3), you will might not have this problem.
bb4srv
Apr 19, 2016 08:49 AM
sanjay
May 30, 2015 04:12 AM
tx2K
May 10, 2013 11:25 AM
GDM S2K
Aug 6, 2010 12:37 PM
Darien1629
May 18, 2005 08:41 AM
