F22 with ap1 ECU
Old Apr 14, 2016 | 09:24 AM
  #31
s2000Junky's Avatar
Originally Posted by HotMess
Originally Posted by darkhorizon' timestamp='1460648243' post='23938059
Just a bump to confirm this. I have an 02 with a F22 swap, and I run VERY lean on the stock ecu(low 14 afr at wot, 16ish during vtec kick). A fuel pressure bump, 65psi at wot, and a VAFC was completely required for both performance and safety. Now running in the 12.8 range flat for afr. Runs very good otherwise.
out of curiosity, had you tried an early AP2 ecu? i just wonder about the cost difference between that, and buying a VAFC + harness + adjustable FPR. I suppose the downside would be a loss of flexibility if you further modified the car (exhaust, intake, etc..)
Sure that would work, but then of course your just running a stock S at that point. Which is fine, just depends on what your goal is. If you want to lower vtec or have any breathing mods, you need to make the NEO/fpr/wideband investment anyway to tune with. With the ap1 ecu you still get the higher rev limit as well.
Old Apr 14, 2016 | 09:26 AM
  #32
camuman's Avatar
used aem 1052U FTW!
Old Apr 14, 2016 | 10:30 AM
  #33
s2000Junky's Avatar
Originally Posted by camuman
used aem 1052U FTW!
Blasphemy
Old Apr 18, 2016 | 05:32 PM
  #34
darkhorizon's Avatar
I need the vafc ($150 used anyway) for the vted mods as mentioned. Could have cheaped out on the fpr for $40 but i went brand name for $100. Aem at $600 is probably a good idea but aem reliability gives me a bit of a bad feeling.
Old Apr 19, 2016 | 09:45 AM
  #35
camuman's Avatar
Ehh. I but my aem 1052u used back in 2009/2010 and it's been fine so far lol
Old Apr 20, 2016 | 02:15 PM
  #36
I've had a bad taste regarding them in MK4 supras, its probably unjustified.
I could throw on a Megasquirt if I wanted to run the DWB cam triggers too..... or if they ever make code for the MS2 that works on the AP1 triggers.
Old Apr 21, 2016 | 05:35 AM
  #37
Reverant's Avatar
Former Sponsor
The MS2 won't receive any new features (including new wheel decoders) as it has reached it's maximum flash space. Our Enhanced MS3 does support the AP1 triggers and is plug and play for the S2000.
Old Apr 21, 2016 | 06:16 AM
  #38
Its been "discussed" that the MS2 was going to get a fixed AP1 trigger setup, but I'm not holding out for it.
I'm well aware I need to grab a MS3 brain but it doesnt fit in the microsquirt socket in the DIYPNP box I have laying around. I may just make a ms2/3.0 into a ms3/3.0 and use the ECU connector I have to make a boomslang type harness for it.
What cam sensor input circuit do you use for the MS3/3.x?
Old Apr 25, 2016 | 07:46 AM
  #39
Reverant's Avatar
Former Sponsor
The AP1 triggers are never going to be supported on the MS2.
On top of that, since the S2000 has sequential fuel and ignition, you will run out of outputs before you know it.
Btw the standard MS3 doesn't support VTEC. Sure you can use a spare programmable output to activate it, but it won't autoswitch maps when you want it to, nor have custom VTEC engagement maps, or customizable coolant gauge mapping, or OBD-II...the list is endless.
Old Apr 28, 2016 | 10:51 AM
  #40
Custom Vtec stuff doesnt interest me, but considering MS3 handles variable camshafts fine, I wouldnt think that vtec would be any more of an issue. MS3 traction control is what I would prefer anyway, and 2 injector drivers will work fine for me, no need for full sequential injection.
As far as OBD2 goes, I would be fine with the CAN bus as it is supported by most anything I would want to use, or I could write the OBD2 headers to communicate with the OBD2 based race computer i have.... Just to make you mad.
FlushS2000
Jul 7, 2012 02:48 PM
yourboysoap
May 10, 2011 08:25 AM
Envied
Aug 11, 2007 10:52 PM
OneQuickS2K
Feb 27, 2004 04:23 PM
